Fezz Parka Mod:
Discussion in 'Telecaster Discussion Forum' started by Toto'sDad, Oct 10, 2011.
  1. Toto'sDad
    Toto'sDad Telefied Ad Free Member
    Bakersfield
    I posted this on the Tech forum, but there may not be many looking over there. I rewired my 52 AVRI to modern wiring today, and also did the Fezz Parka mod. Some people have said it doesn't do much, and it's not a real big difference but it seemed to make the tone control works more smoothly, and it get's rid of the funny little hitch you usually get at the end of the tone control travel when you roll all the highs off.
    Is there any down side to doing the mod? I had a 52 AVRI before that had already been switched to modern wiring and liked it better than the vintage wiring. I tried to like the vintage, but just couldn't. I used the .047 cap, don't know if I should have changed to the .022, but it sounds fine, and the tone control works so smoothly now, I don't know if it would make a whole lot of difference either way.
    Thanks for the advice Telemarkman, though it took a long time for me to get around to doing the wiring, piece of cake as you said.
  2. thejerk
    thejerk Tele-Meister
    Somewhere past East Jesus, WV
    The downside to the mod is that all other non-modded guitars will be annoying from now on!
    Best and easiest mod ever...
  3. Alex M
    Alex M Tele-Meister
    Fort Worth
    No downside. It's just better.
  4. JimmyJam
    JimmyJam Tele-Afflicted
    So Cal
    How does one perform a "Fezz Parka" mod?
  5. yangounet
    yangounet Friend of Leo's
    Lyon france
    +1
  6. krisls
    krisls Tele-Holic
    Sydney Australia
    I built a parts Tele some months back which is my only electric. I went modern wiring, 3 way switch with a .022 cap and the Fezz Mod. I'm not a real twang player, don't like things too bright. With my Kinman Broadcasters this set up works really well for me.
    You can see the Fezz Mod here
    http://www.tdpri.com/forum/telecaste...ou-know-2.html
    Essentially it's an alternative to the treble bleed cap. Shift one wire and keep more highs when you roll the Vol off.
    Works for me.
    Kristina
  7. OuttaspaceMan
    OuttaspaceMan Tele-Afflicted
    Rockwell
    +1
    Same here, on some of my teles it just sounds great while on others - they sounded better without it. Within my experience, it seems like the compatibility of the mod really depends on the general character of the guitar and it's pickups. YMMV. =)
    Here's a visual lay out:
    Or you can move the capacitor instead:
  8. Piotr
    Piotr Tele-Afflicted
    Poland
    Well, the downside is that with the volume control backed off, your tone control starts to function like a second volume control.
  9. Tonetele
    South Australia
    I think it's a great modification-use it all the time because you do retain some control as the volume pot goes down. I'm even experimenting with linear pots. Makes sense to me, position 5 is 5/10 output. Used them on my last build, customer couldn't be happier.
  10. Piotr
    Poland
    My point is that although this mod is fun and simple, still it seems that the best way do handle the treble loss is a cap and resistor in parallel (in terms of preserving the tone as unchanged as possible).
    As for the tone knob, one might try a different cap or profile (linear/log) to make it more to his liking.
    Done some wiring experiments recently, pays off:cool:
  11. TxTeleMan
    TxTeleMan Tele-Afflicted
    Austin, Texas
    I did this mod on my guitar, and I liked it so much I started a thread about it. The downside? I don't know. If you keep thinking about things to much you'll go crazy and undo something that you like for something you don't.
  12. telex76
    telex76 Doctor of Teleocity Ad Free Member
    Fort Worth,Tx.
    I've never had a guitar with a treble bleed that I could tolerate. The Fezz Parka/Ted Green mod is a nice alternative.
  13. felis
    felis Tele-Afflicted
    Antwerp/Belgium
    Maybe a stupid question, but will this work on a Baja volume pot with S1 switch?
  14. psyched
    psyched Tele-Holic
    Raleigh, NC
    The downside is when other people pick your guitar up and dime the knobs!
    As mentioned, it does somewhat make the tone a second volume control, but I think that's just a matter of getting used to the new relationship between the pots. IMO, it makes the knobs much more usable, and widens the sweet spot of the guitar for me. It's sort of like each position now has more range, you can dial in bright/dark in smaller increments but across a more satisfying range.
    Every Tele I've done it to so far, with different pups, I've liked what it does. It doesn't allow you to be lazy with the knobs...
  15. joyster
    joyster Tele-Meister
    Odiham, UK
    Works just fine on mine!
  16. fezz parka
    fezz parka ---------------------------
    Del Floria's Tailor Shop
    No. Most treble bleeds only make the overall tone more tinny as you roll them back. The Ted Greene mod doesn't do this. It's completely natural sounding, where a cap/resistor treble bleed hypes the upper mids and high end.
  17. gypsyseven
    gypsyseven Friend of Leo's
    Germany
    Any pics of the fezz parka/ted greene mod/wiring...?
  18. felis
    Antwerp/Belgium
    Thanks, gonna try this tomorrow.
  19. spankdplank
    spankdplank Tele-Afflicted
    Houston, Tx.
    My two cents, on a tele with two 250k pots, the cap and parallel resistor is better than just a treble bleed cap, but the Fezz Mod is better than either, and is better than standard wiring. If you have a guitar with two 1meg pots, like on a lot of late 60's and most 70's teles, the cap and resistor scheme works best for me. The only possible/slight draw back is that pinky volume knob swells are smoother and seem to require a bit more rolling of the pot with a Fezz Mod and are more abrupt with the standard wiring, and therefore a little easier to do with standard wiring.
  20. Toto'sDad
    Bakersfield
    What ever it is I like it, and I like the modern wiring a whole lot better on the 52, a whole lot. Even though it's only a small thing, it's like getting a new guitar, it's like the guitar has had a gonernor on it, and now it's free to go.
    I am a happy camper now, because I finally have the 52 playing like I want it after fiddling with the setup for days. An offset screw driver is you buddy for the truss rod. Pickup up height is good, relief, nut slots, string height, string gauge, intonation, all good now.
    I also found a used american strat, locked down the temolo and have achieved Yin and Yang balance in my life. After having MANY strats, and never being satisfied with one, I locked the bridge and am a happy camper. In the spring, I think I'll let 'em have pups!
