Hi all - not sure if this would be better directed at a music electronics forum - but I'll give it a go here.
tldr; power section working but no sound out of the pre-amp
So Fender Yale Reverb - just stopped working - don't use it a lot just a spare amp for jams and stuff. Nicely made btw. I have the schematic - the amp is alive from the power stage onwards - the power-amp in jack works. The pre-amp out gives nothing - there is faint healthy sounding hiss and all 3 volume pots seem to work - volume, gain , master all seem to defeat the faint background hiss. So basically there is no pre-amp signal it seems. Checked/cleaned input jack. Touching the pins of the first opamps with a DMM does not give a thing - no pops finding their way through to the power section. All the power rails check out - 15 / 24 / 37V. There seems to be power everywhere just no life. So , my competence level is I can solder and not electrocute myself and use a DMM , I am thinking someone overloaded and blew the first opamp? One - thing - the tone pots were giving strange resistance readings when I took out the board - like 0 - 18k then down to 12k for a 50k pot as I turned - I suspect dirty pots but could they interfere with the signal path?
Sorry for the long read I've added a tldr !
Paul
Paul
