nickd
A good trick is crank the gain flat out and play a harmonic at the 12th, or higher and listen for a long sustained "wooooooooowwwwwwww", if you get "woowooowooowooowooo" then it's probably a bit high. This obviously works best AFTER you have intonated as well.
