corliss1
Are you saying you pulled all the preamp tubes and there is still crackling?
Almost anything.If not such preamp tube what else could cause the cracklng?
Just replaced both of these preamp with other ones i have and scratchy noise is still present. What else could cause this slightly crackling noise in the back ground?
Almost anything.
I had one that I tracked down to it being loose like you said and it was causing intermittent static on the low notes. Once I glued it, no more problems.When you get the new tank, check the inductors. They will probably be loose in their mounts….almost all are. Solidify the inductors in the mounts before installing the tank. I use some super glue. This yields a much better reverb, ime.
And yes….+1 with @GotA24Fretter’s suggestion of finding another tech.
Could it be moisture and carbon composite resistors. I had Boogie mark2 C that crackled problem was resistor.The VK is custom shop built, hand wired and well documented.
Crackling is usually some sort of bad connection.
Use a process of elimination to find where the problem is.
