Fender USA string trees - why do they ping and can you cure it ?
moonman2
England
The question is in the title.
The pingy and scratchy sound is obvious when attempting behind the nut bends.
Is this a common thing or can you fix it without replacing the tree ?
This happens on all my Fender Teles.
moonman2
England
This type
That Cal Webway
Minot
Yep. 100% . I might order the triple string tree from Reverend guitar
G.Rotten
CoolsVille
I think you're nuts.
No wait, I think it's your nuts binding.
No wait, I doubt it's the string trees.
I lube my nuts with lip balm. On traditional string trees I also use the balm but have never needed to on the modern American trees.
moosie
Western Connecticut
It's almost certainly the nut slots binding. Judicious work with a nut file, or a bit of fine sandpaper, but take care unless you want to ruin the nut.
Lubing it with a VERY small amount of vaseline or Big Bends Nut Sauce will help, but it won't last.
moonman2
England
You’re both wrong guys.
I’ve just swapped it out for a Fender Elite string tree, and it’s now silent.
It was nothing to do with the nut.
All my Fenders with those trees have the same issue. Therefore they cannot all have dodgy B and E string slots.
It’s definitely those crappy string trees.
That Cal Webway
Minot
I've used Vaseline and ChapStick, still occurs.
The nut is cut gd. Graphite in slots
Polished that area of the string tree too.
Glad to see the op has found a solution!!
(I do a massive amount of wide interval string bending)
That Cal Webway
Minot
Reverend headstocks must have a deeper cut from the level of the fretboard, because that string tree is way too tall to be useful on a Fender style neck. Ask me how I know this.
If I see that grinding it down won't do the trick I'll probably send it back then.
Thank you for the heads up!
SPUDCASTER
Grangeville, Idaho
My 2016 Deluxe Nashville has that same tree and does the same thing. I'm a Jerry Reed and Donohue fan.
That means behind the nut bends. I've got a round vintage tree laying around. I'll get a little nylon spacer and replace the current one.
Been meaning to do this for some time. Life just somehow gets in the way.
schmee
Never heard of it. You are playing between the nut and the tuners ala SRV? Isn't the 'ping' what you want in that situation?
