Fender tweed in Marshall chassis
Discussion in 'Shock Brother's DIY Amps' started by MojoTrwall, Feb 17, 2021.
  1. MojoTrwall
    MojoTrwall Tele-Holic
    Paris
    Hello,
    After doing every pedal I had in mind and modding my classic 30 and doing extensive research via robrobinette site I want to dig in the diy hole and build my own amp.
    I'd love a tweed amp extensively modded, and I'm not found of the upper panel tweed style due to hardest access to the lower panel.
    Does anyone successfully put a tweed in a Marshall chassis ?
    Is there a place to plan a custom chassis drill, I'm not found of this part of the job usually.
  2. jsnwhite619
    jsnwhite619 Friend of Leo's
    Georgia
    Is there a particular Tweed you have in mind? May help in suggesting chassis alternatives knowing the size, tubes, knobs needed.
  3. MojoTrwall
    Paris
    5f6a.
    I immediatly thought of a jtm 45 chassis, but I'm afraid the dog house cap won't fit due to the tube sockets.
    (Short answer would tell build a Jtm45, but I'd like a bassman).
  4. gigante
    gigante Tele-Meister
    Kansas City
    I can't read today. Nothing to see here.
  5. jsnwhite619
    Georgia
    Go for it! You're 90%+ of the way there from the beginning either way!
    https://robrobinette.com/5F6A_Modifications.htm#Marshall_JTM45
  6. MojoTrwall
    Paris
  7. Lowerleftcoast
    california
    A Marshall 18Watt is a lot like a 5E3.
  8. tubeToaster
    tubeToaster Tele-Meister
    Brentwood,Tn.
    Look at the Weber JTM45 chassis kit. They use a fiberboard fastened to the power transformer mounts to hold the filter caps.
  9. tubeToaster
    Brentwood,Tn.
  10. tubeToaster
    Brentwood,Tn.
  11. Viejo
    Viejo Tele-Afflicted Silver Supporter
    Central IL
    A Marshall JTM 45 is a Fender Tweed Bassman in a Marshall Chassis
  12. Outlaws
    Outlaws Tele-Meister
    None
    I cannot believe there is any appreciable sound difference between a JTM45 with 6L6s and a 12AY7 in V1 from the original 5F6. (And maybe match the negative feedback resistor for feel)
    Speakers are IMO easily over 50-75% of any amps sound from my swapping of heads and cabs.
    So my vote is build a JTM45 and get American voiced speakers to make it a tweed.
    I built a hybrid Bassman/JTM45/JTM50. With greenbacks and 12ax7 it’s all Marshall, with Weber/Jensen Alnico and AY7 it’s all tweed Fender. I added a NFB selector and there is a real change between the bassman and jtm settings, but it’s just in touch dynamics, not sound.
  13. MojoTrwall
    Paris
    Good to hear !
