Fender Tube Reverb Question
Discussion in 'Amp Tech Center' started by burtwangcaster, Mar 1, 2013.
  1. burtwangcaster
    burtwangcaster Tele-Holic
    buckley,michigan
    :confused:I recently bought a used Fender Tube Reverb R.I.
    It seems to work fine but I noticed it has two 12ax7's in it rather than the
    12AT7 and 7025, called for in the tube chart.
    Should I worry about it or not ???:?:
  2. andyfromdenver
    andyfromdenver Friend of Leo's
    grandpa's
    No need to worry per se.
    However, it's not correct.
    A 12ax7 in V1 is fine.
    A 12at7 in V2 is how it was designed.
    You can also change the big' 'un to a 6k6 which was the design intention too. Find a good oldie somewhere.
  3. telex76
    telex76 Doctor of Teleocity Ad Free Member
    Fort Worth,Tx.
    I'd put the "correct" tubes in. Might make a difference, might not.
    You always want to have extra tubes on hand anyway.
  4. BiggerJohn
    BiggerJohn Friend of Leo's
    California
    Yeah, put the correct tubes in it.
    I agree on putting a 6K6 in as well for the reverb driver.
  5. burtwangcaster
    buckley,michigan
    Thanks to everyone. Now another odd thing I found, [not the ones out of the reverb unit]a tube that is marked
    12AX7 AND 7025......what's with that?
  6. BiggerJohn
    California
    Same thing. 7025 was a low noise version of 12AX7.
