The Long Answer: If there are fireworks, shut it off and don't turn it on until you replace both power tubes and set the bias. You don't want one of them to short internally and maybe take other components along for the ride. Be disciplined and shut it off.
A matched set of 6V6-GT or GTA is best. We spent a few decades shoving whatever tubes we had into our amps and generally were lucky, but matching prevents a pair from having wildly differing current draws and one of them redplating while the other is fine. The SCXD has a single source of bias voltage that's the sum of the voltage for both tubes. You can't bias individually, at least without replacing a fixed resistor, so a matched pair is best. You will need to check and set the bias voltage. If you're comfortable working in a chassis with LETHAL VOLTAGE that's live, then you can set the bias with a multimeter. If not, take it to a tech. The Fender spec for the sum of the two tubes is 40 mV. Old stock tubes from the US, EU, UK, and Japan can take 45-50 mV, usually. Bias by ear between 40 and 50 mV and set it where it sounds good to you. A JJ 6V6S set can take 45-50 mV. They're a bit more defined and bright than a 6V6-GT.
A used, matched set that tests good, from a proper tube dealer, will likely last for the life of the amp if it isn't gigged. NOS is fine, as well. If you're looking to save some money, you can get a mixed, matched set as long as they match well. Example: A GE 6V6-GT with a top-getter can coexist with an RCA (rebranded "Conn Organ") 6V6-GT with a side-getter.
Current production tubes? Some are good and some are crap. There are some reilable sources that test and weed out the crap and you'll pay a bit of a premium for that service. My experience is that NOS or used OS last longer, often sound better and I'll pay the price for that.
Here are reliable dealers I've bought from multiple times. There are other, good dealers. I've listed my tube choices, per my experience with blasting an SCX2 (same circuit as yours) pretty loud. There are subtle differences at both low and high volumes, but all will sound good.
KCA Nos Tubes The owner is a member over on Strat-Talk. From
their 6V6 page,
GE 6V6-GTA. $95.00 for a matched pair. Good all-around tube.
Philips JAN 6V6-GT. $84.00 matched pair. Military tube. Stays a bit more defined when cranked. A good price.
Sylvania JAN 6V6-GT. $95.00 matched pair. Military tube. Stays a bit more defined when cranked. Basically the same tube as the Philips, so I'd get the Philips because of the lower price.
Audio Tubes The owner is Brent Jessee. It's best to order over the phone. Prices tend to be a bit better on the non-holy-grail tubes than KCA pricing.
The 6V6 page.
6V6GTY JAN military type brownbase, all USA made brands. $70.00 for a matched pair. Mixed brands and/or markings. That's not a problem.
6V6GT General Electric. $50.00 for a matched pair. Relabled with multiple brands. Good all-around tubes.
6V6GT Sylvania blackplate 1950s greyglass or clearglass. $70.00 for a matched pair. A bit brighter.
6V6GTA RCA clearglass. $80.00 for a matched pair.
The Short Answer: If there are fireworks, shut it off and don't turn it on until you replace both power tubes and set the bias. You don't want one of them to short internally and maybe take other components along for the ride. Be disciplined and shut it off.
Take it to an amp tech.
By The Way: Get an inexpensive NOS or used OS 12AX7. You might as well put it in to replace the OEM tube the amp came with. Save the one you take out.
