Fender String Spacing Noiseless P90 Sized Humbucker...Do They Exist
Discussion in 'Just Pickups' started by ktdcpa, Aug 25, 2019.
  1. ktdcpa
    ktdcpa TDPRI Member
    Seattle
    ...Well I know Fralin and Lollar make versions with 53MM spacing. Also, the Dimarzio Bluesbucker is supposed to be in ballpark. However, does anyone else make them? I see Tom Anderson offers a line of P90s on Fender style guitars, but for the life of me I can't track down the bridge spacing.
    Before anyone says string spacing doesn't matter, please know I generally agree. However, I'm building a custom Jazzcaster/Telemaster and I want it to look perfect :). So, with that said are there any other P90's I should consider?
    Thanks for your time and insight!
  2. Teleterr
    Teleterr Friend of Leo's
    Lewes De.
    I have a P 90 sized HB made by Bartolini, no poles showing. I think Bluesbuckers are normal HB sized and close to normal construction, just supposed to sound P 90 ish.
  3. sothoth
    sothoth Tele-Holic Platinum Supporter
    Kepler-186f
    Ask Sunday Handwound to make you a set (custom), which I believe he can. He made me a set of vintage Gibson sounding soapbars that sound really sweet.
    Or just realize the standard/f-spaced thing is mostly aesthetic and will play just fine if it’s a mismatch, and don’t worry about it.
  4. Golem
    Golem Tele-Holic
    United States Of America
    Kinman has Noiseless pickups with 53mm spacing. [​IMG]
    I absolutely agree that spacing can matter, although it really depends on the height you set the pickup. If you like them lower you really won't notice (except visually) that it's a bit off. If you have them set high enough, the string spacing being off can be an issue.
