Fender/Squier Mustang tone question
  • Thread starter srblue5
srblue5
Alberta
I don't own any offset Fenders currently but of all of them, I feel like I am the least familiar with the Mustang. For anyone who has played or owned a Fender (or Squier) Mustang, how would you describe the tone? Any good (non-grunge -- I tend to play clean or with mild overdrive) examples of a Mustang's tone?
Two slanted single coil pickups. Should sound Tele-ish or Jaguar-ish, no? I imagine the short-scale, vibrato bridge, and other unique qualities make it different, though.
Ok, full disclosure: I am considering acquiring a Mustang as a new toy to mess around with over the winter months (especially if Covid cases continue to rise locally). Eventually, I would like a Vintera Jazzmaster or Jag but that's not in the budget for the next year or so.
Steve Holt
Kansas
Of all the big fender guitars I've never played a mustang! I'm curious to see the answers though. I love Jags and Jazzmasters. But I've never found the mustang that appealing for some reason.
ReverendRevolver
Ohio (Nerk)
Current production mustang pickups leave much to be desired.
The 70s one I frequently borrowed had it's own thing going, they were kind of mellow, but if you used the knobs like it was a tele, you could dial in distinct and usable tones. Darker than a strat, not as diverse as a tele. Nice bottom end, but not excessive. Highs were good, but not overkill.
Now, I've only played other vintage stuff in guitar stores, and the Japanese reissues don't sound like the old ones. They mostly have usable sounding pickups, and play great. Like a hair less bright strat pair on some. The "jd" serial numbers had good feeling necks.
The modern MIM Mustangs and duosonics do not have great pickups. I had Buhdda make me a custom set for my Duosonic, which really brought it to life. They're like hotter versions of the 70s mustang sound, which translates to them behaving even more like a tele with the knobs.
The modern stock mim pickups seem like just mediocre strat bridge and middle pickups. Not ideal.
The US performer 'stangs sounded better, but not really like the old Mustangs.
My pawnshop series mustang had pretty but boring sounding humbuckers stock, those were changed as well.
I guess to really answer the question, any current model mustang will do, with better pickups. I cant point to direct examples of tone, but Johnny Winter used one sometimes, and several modern alt rock bands (they're normally plugged into reverby fenders).
The switching, which is phase-off-phase on both pickups let's you do limited utility out of phase stuff, but more importantly, go from both to one with a thumbnail motion, if that's faster than a toggle for you.
Trem is unique, and IF setup right is neat.
The Japanese ones are best value for money right now. If super budget, the squier.
The pickups are the worst part of most I've seen though. Duncan, Fralin, and custom winders all make replacements.
3-Chord-Genius
Winchester, VA
I used to have one of the original early 1970's Fender Mustangs. The sound was "rounder" than a Stratocaster. Look, I hate idiotic guitar buzzwords also, but that was the first where they came to my mind. I liked the tone of those two pickups more than the three on my stratocaster.
trev333
Coolum Beach,Australia
I thought the two single coils sounded much the same... so I swapped out two matched strat pu's to a ceramic mex strat neck and a rails bridge....
and changed the wiring sliders into a n/n+b/b and series/par/split for the bridge pu...
Boreas
Adirondack Coast, NY
I currently have a 90's MIJ Mustang reissue, and had a 69 for a few years. The 69 was a better guitar, but the MIJ isn't junk. They both sound like Mustangs. Nothing spectacular, but their own tone. Changing pots and fiddling with pup height can massage the tone considerably. To me, they sound closer to a Strat than a Tele, because the neck and bridge pickups are very closely matched. I found the 69 to have a better whammy. I had trouble getting the MIJ to return to tune because of the bridge design that seems to be using softer metal for the pivot point now. I switched mine over to a modified Chigsby and the problem was eliminated.
I would also say my Fender Duo Sonic sounded very similar to the Mustangs until I replaced the PUPs.
Hounded Dog
Vancouver BC
I think the Mustang trem is of questionable value. It was hard to tune and went out if touched on my '66. I think it made the guitar plinky. It sustained like a banjo. I hated it and got rid of the guitar. I hope others had better luck. That said, it had a unique voice and was great for thumping away with triads or power chords.
MrCoolGuy
Fort Worth, TX
Mustangs are my thing, I'll admit that.
I have a Squier VM Mustang and a 1965.
The 65 is far and away a better guitar, but I still love the Squier. Mustangs in general have a unique sound. "Jangly"
Is an adjective often used, but I like to lock the "vibrato" system which eliminates the jangliness... the pickups are somewhat lower output than a strat, but when you use both pickups in phase, you get a very strat-like sound if not somewhat rounder or warmer. The neck pickup alone will give you a very warm, round tone due to its proximity to the middle of the strings (due to the short scale). The bridge alone gives you a sharp powerful attack. The short scale is also convenient because you can use thicker strings without getting too much tension. This allows you to use lower tuning. As far as playability, the old Mustangs are hard to beat. Lightweight and small. The necks, whether B or A are small and thin. And small frets aren't for everyone, but I love them. You can really feel the fretboard especially when playing bar chords.
The trem, though I generally don't use it, is actually a lot better than you will read on most websites. The problem most people have is not setting it up correctly. (I'd be glad to help, just ask) ...there's a trick to it. I don't think they sound at all like Jaguars or Jazzmasters... more like a strat, but really it's own thing. I hope this helps. Any more questions?
Blues Twanger
SoVT
Two pickups yes but they don't sound like Teles. They can either be bright and jangly with the more 'correct' low wound pickups but can get thicker and growly with overwounds.
Mojohand40
manassas,va
I own a vintera mustang and have played a few vintage ones.
I don't play grunge, I mostly play clean.
IMO, my mustang sounds great for early 60s garage rock, go-go, weird b movie soundtrack type stuff. Thin, jangly, not a lot of sustain.
For something modern in this vein. Look for YouTube videos by a band called "Bang! Mustang". Fun surf stuff.
I use mine to play real early surf rock. Listen to the "The Challengers" album "Surf Beat".. very mustangy..
Sundazed records has a collection of albums "Lost Legends of Surf guitar " that has a few obscure mustang tracks.
(I think)...
A lot of real early, Surf Rock/Garage bands used Mustangs...early 60s., most either went to Jags or Jazzmasters later, but the early, early stuff was done sometimes with mustangs simply because they were way cheaper than other Fenders.
My 2 cents.
MrCoolGuy
Fort Worth, TX
(I think)...
My 2 cents.
Couldn't have been too early 60s, eh?
They came out in 64.
Reedo
Suffolk UK
I've owned a few. Love the appearance, but never got on with the playability. The last one I had was a Performer, but swore I would never go back to them again after I sold it on in 2019. Same goes for Duo Sonic's, just not a fun instrument to play for me, you may have better luck.
