iamthesteve
I totally get this, but, some people buy puzzles to relax in their free time, I like solving things. I personally enjoy learning now things work, and fix them if I can. It's quite a rush if I can figure it out.
Hi, I just joined to reply to this thread.
In my case, there's nothing relaxing about this puzzle... but having this amp apart eats away at me in the back of my brain...
My initial problem was that the power supply showed no signs of life past the AC input section.
I ordered some parts that I thought were possible suspects and replaced them.
After replacing the PWM controller, it now blows the fuse, which I take as progress.
I ordered some replacement power MOSFETS, but the existing one measures the same (as the new) out of the circuit so I left it in.
I also replaced the little 4-pin optocoupler which didn't make a difference.
I agree that this circuit isn't worth spending time on. Just wanted to subscribe to this thread in case anyone learns more.
I spent a couple hours yesterday scouring the internet for a suitable replacement switching power supply, but came up empty.
The closest search string I came up with was:
switching supply pcb "28v" "dual output" "open frame"
As you all know from the schematic, we just need +/- 28V and a 5VDC output.
If we could just find a +/- 28VDC supply we could easily add a little 5V supply and fit it in there.
Edit: I should have added that the output connector is disconnected.
Also, I did not have the problem of the OP, as mentioned. No initial signs of life past the AC input section. Good fuse initially.
