johnnybregar
After a LOT of sleuthing and research, I believe that the issue with my player telecaster, is that the neck angle is incorrect. I am experiencing string buzz all the way up the neck from the first fret. It’s mostly on the 4th,5th and 6th strings. It’s not just a pleasant jangle - it is quite annoying, and comes through amps or going direct.
I tried leveling the frets, adjusting the relief, adjusting the action, raising the action ridiculously high, reseating the neck, adjusting the intonation, and checking to make sure it wasn’t the nut or some other vibration. I ended up shimming the neck, and the problem went away.
Then I went back to measure the action above the 12th fret as purchased and saw that it got lower as it got close to the body instead of higher as it should. So then I knew I had a neck angle issue. At least as far as I understand it.
Now that I’ve fully bastardized it (as well as installing Loller Pickups), I feel like I can’t really sell it as is, so I want to try a new neck on it.
I ordered a player Tele neck from Stratosphere and I’m going to see if perhaps the problem gets resolved.
My questions:
1. How often does one need to sand the heel of the neck to get a good neck angle when doing a replacement? I am planning to at least try that on my old neck, but I need to find a sanding wheel so I don’t mess it up.
2. Would you sand the heel of the neck, or would you try to alter the slot on the body?
3. Can I put a player neck on an American Perfomer body if I find one? If I end up getting my original neck to work well, I might sell that guitar and make a partscaster. Why? Cause I’m sorta pissed at this guitar and I just wanna start over.
I just wanna play my dang guitar. I should have brought it to a dealer right away but I usually do my own setups, and I’m actually pretty darned good with fret work if I don’t say so - so I figured that hitting the high frets would solve the problem.
I’d love some input.
Thx.
Johnny
My questions:
Thx.
Johnny
