Fender Pilot Light - doesn't fit right in Princeton Reverb chassis
Discussion in 'Shock Brother's DIY Amps' started by Lavely, Feb 23, 2021.
  1. Lavely
    Lavely TDPRI Member
    Minneapolis
    I'm building a RobRob Champ Micro in a Princeton Reverb chassis (LOTS of room!). While installing the indicator light, I am noticing that the slant of the front panel means the indicator assembly doesn't really fit well in the chassis:
    [​IMG]Untitled by joelavely, on Flickr
    Meaning, it touches the chassis itself when installed properly. RobRob suggested I add a nut or two to the outside of the chassis (the front panel side) so the unit doesn't poke as far into the amp chassis as it does now. Sounds easy enough...except, when I go to find a couple nuts to add, I'm not sure what size to use! Anyone have specs for the nut shown here holding the unit to the chassis? I would add a couple to the outside, which would make the body of the assembly protrude further out the front side, hopefully not touch the chassis. I have found different specs - one says 9/16-24, another says 1/16-27. Because this has an inside screw receptacle as well, not sure which to buy?
    Also, how about a source for cheap nuts!?!?
  2. SerpentRuss
    SerpentRuss TDPRI Member Ad Free Member
    North Carolina
    Call me dense, but even if more of the holder is on the other side of the amp face, the angle of the threads into the chassis is going to be the same and when it's snugged up you're going to be in the same relative position, right? Why don't you rotate the back part of the assembly 90 degrees counterclockwise? That will put the flat of the holder against the chassis and it's grounded. As you tighten it up, the holder will bend but the inner lamp holder won't. It will still shine through your jewel.
  3. Lavely
    Lavely TDPRI Member
    Minneapolis
    @SerpentRuss - I think if I move it "out" the front, the back that's on the chassis now will not shift angle, but will move closer to the front panel, creating more clearance. No?
  4. SerpentRuss
    North Carolina
    The steel part that has the part number, is the front of that touching the front panel? It's hard to tell from your photo. If not, then I guess you have a little to gain there, If it's touching, you don't have anywhere to go.
  5. Lavely
    Lavely TDPRI Member
    Minneapolis
    Geez - of course you are right!!! Is there a face-palm emoji?!?
    OK - so, someone tell me - how am I supposed to install this vintage Fender lamp in a vintage Fender chassis? There must be a common solution...this isn't a new problem?
  6. thechad
    thechad Tele-Holic
    Kamloops
    Bend it at the folds of the metal arm with the part numbers. The part that bolts to the chassis needs to be bent so it will go parallel to the bottom of the chassis, then bend the bulb holder side so the lamp points to the jewel.
    Viejo and glenlivet like this.
  7. Lavely
    Lavely TDPRI Member
    Minneapolis
    Looking at some PR chassis pics online, many look like this is not a problem, which baffles me. Others have some fiberboard screwed to the chassis to sit between the chassis floor and the metal of the light assembly.
    Junior Little and zook like this.
  8. Lavely
    Lavely TDPRI Member
    Minneapolis
    @thechad - I have tried a few variations on your idea, except one piece - will give it a shot tonight
  9. thechad
    thechad Tele-Holic
    Kamloops
    Be sure to remove it from the chassis before you bend it so you don’t accidentally damage the chassis. And remove the bulb as well. I would try orienting it 90 degrees to the way it currently sits. Kind of like this :
    If that makes sense.
  10. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    Just bend the whole assembly upward. The lamp will still show through the jewel. The bulb isn't centered as it is.
    King Fan likes this.
  11. thechad
    thechad Tele-Holic
    Kamloops
    You would still like to be able to change out the bulb by only removing the jewel and not having to open up the whole chassis, so don’t bend it too much askew.
    Boreas likes this.
  12. schmee
    schmee Doctor of Teleocity
    it's not uncommon at all. I have seen vintage fender's with a strip of that thin fiberboard under there. As Thechad said do this:
    -Bend the piot lamp assembly so that is is off the chassis:
    First bend the angle near the faceplate end to a tighter 90 degrees. Then bend the right angle at the back of it to get the pilot lamp more centered again. Easy Peasy.
  13. King Fan
    Salt Lake City
    What PR chassis are you using? I wonder if the front angle varies at all? Me, I wouldn't extend the lamp out the front with spacers, but even if I did I'd try to find a nice hi-grade washer or two, not a hex nut.
    My Mojo PR chassis a few years back had plenty of room for the lamp. Hmm, did I bend the lamp's housing, as the guys are suggesting? Looks like maybe so. That'd explain why I mounted it with the housing down, for fairly obvious reasons, to simply bend it to a somewhat greater angle.
    Or, as noted, mount it sideways and RTV a small chunk of fiberboard under the housing -- this is my vintage '67 VibroChamp, and the same thing worked well with my 6G2 build.
    jsnwhite619 likes this.
  14. Phrygian77
    Crawfordville, FL
    Blue Bill and jsnwhite619 like this.
  15. Muzzy
    Muzzy TDPRI Member
    I would grind or file a little bit of it off to gain more clearance.
  16. Lavely
    Lavely TDPRI Member
    Minneapolis
    Pretty simple solution, as several above outlined. I ordered the McMaster fiberboard from Post #14, screwed it into the chassis, barrier made, problem solved! Also bent the housing a little bit, as suggested. The "after" pic:
