Fender P-Bass Pickup - Different magnetisation between E+A and D+G sections?
Discussion in 'The BASS Place' started by NeilMcG, Nov 22, 2017.
  1. NeilMcG
    NeilMcG TDPRI Member
    Cambridge, UK
    Just got a new P-bass pickup (Fender Original Vintage #0992046000 - alnico 5, "vintage 62" design) and in the process of messing around with it I offered up an allan key to the pole pieces to see how heavily magnetised they were.
    It looks to me like the 4 poles in the D+G section of the pickup are more heavily magnetised compared to the 4 poles in the E+A section. (the level of magnetisation appears the same within each section though)
    Has anyone else seen this? I've never seen this mentioned before, but it looks like a way of balancing the different string output.
  2. Cadfael
    Cadfael Tele-Meister
    Dortmund, Germany
    Never heard of it...
  3. NeilMcG
    Cambridge, UK
    Installed it today and it works fine, so that different magnetisation level must be intentional.
    I thought one of the pickup gurus on this board may pipe up with more info. I'll try TalkBass, see if anyone knows there. I'm curious!
  4. Cadfael
    Dortmund, Germany
    For a P62 there is NO NEED for different magnets as each string an be hights-adjusted by the PU.
    AND I did a lot of research on Leo's work.
    He made everything as simple as possible for his workers (to keep a qualtiy standard). Different magnets? No...
  5. BCbassman
    BCbassman TDPRI Member
    Washington D.C suburb
    Well he did not say that the magnets were different, just that one half of the pickup was more heavily magnetized. I suppose that is possible because its probably impossible to make two halves of a pickup exactly the same magnetism. The pickup is humbucking as all P-bass pickups and that is what makes them work so well.
