Fender Neck Thickness
Discussion in 'Telecaster Discussion Forum' started by shodan144, Sep 3, 2019.
  1. shodan144
    shodan144 TDPRI Member
    Indiana
    OK, total newbie here. I am curious about the origin of the standard 1" Fender neck thickness.
    I was routing out a body and accidentally made the neck pocket the same depth as the neck pup. Instead of 5/8", I wound up with 3/4". In my infinitesimal wisdom, I compensated by making the overall neck thickness 1 1/8".
    The result was a neck that was a bit on the clunky side but exhibiting wonderful sustain.
    Is this a total fail or can it be more of a feel/preference thing?
    Thanks in advance for your input...
  2. Tim S
    Tim S Tele-Holic
    Upstate NY
    Edit: Nevemind (Reading is fundamental). :)
  3. Macrogats
    Macrogats Friend of Leo's
    Auckland, New Zealand
    I’m sure the experts can give you some more “expert” opinions, and I’d be interested to know, cos I have a neck blank cut to shape that’s at 21mm. My plan is to use a 5mm Fretboard and take my pocket down an extra mm to 17.
    Obviously I can shape the neck profile to what I want, so the only difference will be the slight extra thickness at the heel.
  4. Luthi3rz
    Luthi3rz Tele-Meister
    AZ
    Never heard of that. Rough lumber is Sold in factions like this 4/4 5/4 8/4 12/4
    with 4/4 being about 1" inch thick and 5/4 being about 1 1/4" 1 1/2 or something like that.
    Maybe that's why.
    Were Fender's first Necks all 1 piece?
    Edit
    Rough Lumber
    4/4 means approximately 1″ thick
    5/4 means approximately 1-1/4″ thick
    6/4 means approximately 1-1/2″ thick
    8/4 means approximately 2″ thick
    12/4 means approximately 3″ thick
    Crafty Fox likes this.
  5. eallen
    eallen Tele-Afflicted Silver Supporter
    The thing that counts for setup is that the top of the fretboard is the same height above the guitar top surface. Technically how you get there doesn't matter. As for the chunky neck, you could or can take more material off to gain the desired thickness at the 1st & 12th fret. The only place the thickness really needs to exist to compensate is the neck heal.
    All that said, someone brought me a body to make a neck for. I realized the individual had routed the pocket to 3/4" deep. When I told him the additional cost for a thicker piece of wood for thickness needed for the neck he requested I glue a piece into the pocket to make it the correct depth. While you can make a thicker neck work, no standard neck will fit it, should you decide to ever change it.
    Eric
    Steve Holt likes this.
  6. Crafty Fox
    Crafty Fox Tele-Afflicted
    Perth Australia
    Thanks for posting this, now I understand what your US measures mean.:D
    eallen and Luthi3rz like this.
