Fender neck hole spacing question
Discussion in 'Tele Home Depot' started by tvrfan2003, Jan 15, 2009.
  1. tvrfan2003
    tvrfan2003 TDPRI Member
    canada
    I have purchased a Fender Special Edition Lite Ash neck (Korea) for a tele build...most templates indicate 2 inch x 1.5 inch square pattern for holes on heel of neck, but this one has holes that are spaced 2 inch horizontally, but the vertical spacing is 1.5 inches at "heel" end, and 1 7/16 for the pair closer to the tuner end...small difference but clearly narrows as the heel itself does? Is this normal, or are the Korean fender necks drilled differently?
