James64
Hello,
I have a Fender MP Tele Plus (Tele neck, Strat middle, Humbucker bridge (3 wire plus bare, wired in parallel which I like). It has a 5-way switch. I had replaced all the pickups with Fender Vintage Noiseless. And I replaced the coil split switch with a neck on switch. The noiseless neck is ok (could be brighter), the noiseless middle is my least favorite middle pickup (I really don't like it at all) and the noiseless bridge is ok but a bit bright (I'd rather have a bright humbucker (a little bit thicker). I guess I really just don't like the noiseless middle.
Anyway, I want to go back to the original pickups, but without the coil split (the split coil was too weak for me and the 2nd position didn't have any magic with that weak split. If I put the original pickups back in, without the split, I'll basically have something similar to a Strat SSH.
The green and bare go together to ground and the red (hot) goes to the volume pot. So, my question is... what do I do with the white wire? Just leave it hanging (taped off)? When I tie the green and bare together and then measure resistance between that combo and the red wire, I get 8.68k ohms. I'm confused as to how this guitar will work with the white wire just "floating".
Thanks for any advice!
