Fender Hot Rod Deville mod kit
Discussion in 'Amp Central Station' started by brian79, Dec 21, 2013.
  1. brian79
    brian79 TDPRI Member
    Illinois
    I have a hot rod deville 410 that I have been considering the frommel mod kit and recap kit and I was wondering if anyone has had good results from it? I use the amp mostly for clean stuff and occasionally with an overdrive pedal. I bought the amp new in 99 and it still has the original tubes in it. Before I consider any major permanent mods I will be replacing the tubes to see if it makes any improvements.
    Thanks in advance.
    Brian
  2. Prairie Dawg
    Prairie Dawg Tele-Meister
    Windsor Heights, Iowa
    The only thing that you need is a well set up pair of power tubes and new electrolytic caps. I highly recommend F&T. That is all your Deville will need to sound its best, and you do not need any ill advised "mods".
  3. JCBurke59
    JCBurke59 Tele-Holic
    Long Island, NY
    My son gigs an older DeVille 410. After picking it up used a couple of years ago (and not knowing anything about its history) we cleaned it up, replaced all of the tubes and did a re-bias. That alone got it to a very good place sonically.
    I can't speak to the entire Fromel mod, but the audio taper pots to replace the stock linears and the Switchcraft jacks (not board mounted) seem like an excellent idea to me. As far as the Fromel tone-related mods go, the stock amp here sounds just fine without them - but I'd sure like to hear one 'fully' modded, just to compare. :cool:
  4. brian79
    Illinois
    Thanks for the info. The cap kit has 6 F&T caps and a few other smaller caps. The "mod" kit doesn't really change the circuit,its mostly just supposed to be better parts. It has 2 orange drops, 3 mica caps, 2 power resistors, several 1/2 watt resistors, a new volume pot, and 2 new input jacks. It has a small jumper wire that can be added to bridge pins 2 and 3 on the mid pot for a "tone stack mod". I am definitely going to order new tubes and rebias it. Then probably have the electrolytic caps changed. I had the input jacks changed while it was still under warranty so the other part of the kit may not offer] enough of a benefit to risk any damage to the pcb.
    http://www.tdpri.com/forum/attachment.php?attachmentid=211408&stc=1&d=1387659557
      File size:
      27.2 KB
      338
