Fender Excelsior Eating Preamp Tube
Discussion in 'Amp Tech Center' started by Newzpix, Mar 6, 2013.
  1. Newzpix
    Newzpix TDPRI Member
    Near Mount Vernon, Va
    Something isn't right. I've gone through 4 V1 preamp tubes in the past 6 weeks. Then today, after playing for a few minutes, the amp started popping, then hissing, then all hell broke loose and she was screaming.
    I'd put a new preamp tube in V1 and the amp would be sweet for a few days - week....then it would get noisy. Repeat process and the symptoms would appear again.
    I looked at the V1 socket from inside the amp, thinking a bad solder joint or loose contact, it looks okay.
    Symptoms are the same with a change of power tubes.
    Grrrr.........
  2. Telenut62
    Telenut62 Poster Extraordinaire
    Eugowra, Australia
    Buy it new?...take it back. Second hand?....take it to a tech, unless you know how to use a DVM.
  3. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    What kind of tubes you useing ?
  4. Newzpix
    I don't think it's the tubes...but to answer your question.
    EH 6V6
    JJ, EH, and assorted preamp tubes from my stash - mostly NOS GE, JAN, etc. I even tried the preamp tubes from my Tweed Deluxe which I know sounded sweet.
  5. BobbyZ
    Snellman MN
    Ok I was just thinking if you were blowing the same brand of tubes maybe you just got a batch of bad ones.
    That was the only idea I had other than ripping into it.
