everythingyousee
I have what I believe to be an AB868 on my bench. Silverface with the push/pull volume boost on the Vib channel. 5U4 rectifier. All the small tubes are 12AX7, no AT's in there...
Amp sounds very muddy and distorted, especially in the lower frequencies.
It has had some work done before including most caps and some resistors.
I am consistently getting higher-than-expected voltages throughout the chassis. I have the amp powered up through my Variac at exactly 120v and here are a few voltages I've measured with the amp powered on:
-line voltage entering PT: 120vac
-primary wires to 5U4: 370vac vs 330 on schem
-B+ coming from standby switch, before reservoir and OT centertap: 468vdc vs 420 on schem
Bias pot connected to 6V6 output tubes: -60vdc vs -35 on schem
Plate voltage on output tubes: 450vdc
PIlot light: 4.2vac vs 6.3 on schem
Heater on V1: 1.3vac
Could this be a bad PT?
