Fender Deluxe pop when switch channels
Discussion in 'Amp Tech Center' started by tiki16, Jun 5, 2016.
  1. tiki16
    tiki16 NEW MEMBER!
    Upstate New York
    Hello all! I have a fender deluxe hot rod. I recently replaced one of the inputs that was busted. It was causing major noise problems, I think because of the grounding.
    I've noticed that when I switch channels back and forth there is a loud pop. It happens with foot switch and on the button. This also happens when i toggle between pickups on the guitar. I've tried different cables, same problem. Even on low or high volumes there is a pop. Any help appreciated.
    Thanks
  2. Platefire
    Platefire Friend of Leo's
    North Louisiana around Many
    I think you need to go back and check your input jack installation if it all started happening after that.
    The ground connection/solder joint could be bad. Platefire
