Fender BXR 200 Fuse replacement
Discussion in 'Amp Tech Center' started by JFBP, Aug 4, 2021.
  1. JFBP
    JFBP NEW MEMBER!
    California
    I have a Fender BXR 200 I think needs a Fuse replacement.
    Any advice on how to pull the chassis to check this? The manual does not have a diagram.
    **I'm just looking for advice in this issue please. The amp will go to a tech if the fuse is blown.
  2. Jon Snell
    Jon Snell Tele-Holic
    Jurassic Coast. Great Britian.
    If the fuse has blown, check for short circuit output transistors before fitting a new one of the same value and type.
    If the combo model, remove the screws on the top to slide the chassis out.
