Fender Blues Deluxe RI TOOOOBS
Discussion in 'Amp Central Station' started by StuartJames, Feb 26, 2021.
  1. StuartJames
    StuartJames Tele-Meister
    I’ve been finding my BD a bit bloated in the bass and struggling to get a good clean tone at band volumes. It has a Cannabis Rex speaker. I use it as a clean platform with pedals. I run the bass on zero usually.
    The last couple of weeks I’ve been trying the drive channel with master fully cranked and turn up the drive to desired volumes. This sounds pretty good and I can roll back vol on guitar for decent cleans. All that excess bass disappear in the drive channel
    Today I replaced the V1 12ax7 tube with a 12ay7. This is a pretty remarkable improvement for the clean channel , way more balanced and better control over the volume. However the drive channel, while still sounding decent, has very little gain unless fully dimmed. This is to be expected by from adding a lower gain tube I guess
    Is there any tube combinations that would get me best of both worlds? I haven’t experimented with putting the 12ay7 in the other positions yet. Is there any value doing this? Could a tube change in v2 help the get a touch of gain back?
    Cheers
  2. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Where are you setting treble? People don't realise but treble in the FMV tone stack acts like a global gain control for mids and bass. Much past 5-6 you can find bass falling apart unless it is dropped way low.
    Try using a 12AT7 or 5751 in V1. That will still get the gain drop to make clean better, but also keep range in your drive control.
    StuartJames likes this.
  3. StuartJames
    I usually set it in the 5-7 window
