Fender Acoustasonic Telecaster: Opinions, praise, criticism and warning.
Discussion in 'Telecaster Discussion Forum' started by spkguitar, Dec 2, 2019.
  1. spkguitar
    spkguitar TDPRI Member
    McDonald, PA (Pittsburgh)
    TL;DR - The Acoustasonic has some design problems that you should consider before purchase.
    So... I bought the Acoustasonic Tele back in April of 2019 for my work in an acoustic cover trio. Everything from Eagles to Imagine Dragons, Elvis to Portugal the Man, etc. For this purpose, the Acoustasonic is pretty stellar feature wise.
    Would I ever choose it for pure acoustic tone? Nope.
    Would I ever choose it over of a real telecaster for full-on electric guitar work? Nope.
    But for switching tones song to song and even mid-song in an acoustic cover situation for drunk people in bars who don't really care that you're faking them out, it works wonders.
    I'd like to give my honest opinions and experiences about the instrument in case anyone is looking to purchase or is just curious.
    First, the instrument comes without a string retainer, which I found to be flawed. The very first weekend of use, I kept popping the high E string out of the nut (I play pretty aggressively). Less than $5 worth of parts later, that problem was solved, but I really shouldn't have had to drill into my brand new expensive instrument to solve this problem; it should have come with them.
    Next, I'm not a big fan of the charging/battery system. The Micro USB connecter is flimsy at best, and I strongly feel that there could be a better way to charge than this tiny connector. Something like the Line 6 TRS connection or something like that. With that said, playing 2-4 shows in a row just didn't sit well with me in the "trust the battery" department, so I created my own "snake" cable with 1/4" and USB charge cable, so I never have to worry about the battery dying; it's always plugged in and charging.
    Moving on, there is no pickguard. This makes the guitar attractive in looks, but isn't very practical when torturing it night after night. I started chewing through the top right away, so much so that I ordered clear, thin stick-on pickguard material from stew-mac and cut it to fit, but honestly, the damage was already done. I will eventually have a "trigger" on my hands, if you know what I mean.
    After 8 months, the frets are really starting to wear. I do play alot (80 3-4 hour shows on this instrument), so this isn't as surprising as I guess I thought, but still...
    And now we get to the warning part of my review; string retention and the electronics. The Acoustasonic uses a standard acoustic bridge pin retention for the strings. On a standard acoustic, if you break a string and the ball end falls into the guitar, you can normally shake out the ball end through the sound hole. With the Acoustasonic's design with the figured mahogany block at the sound hole, this is not really possible (or at the very least EXTREMELY difficult). I found the only real way to get the ball ends out when they fell in was to unscrew the back plate to shake them out. Impractical at best when gigging frequently. And now we get to the real problem; the delicate electronics on the inside are not at all protected. They are wide open.
    So there is the potential for the loose ball ends to come in contact with the delicate circuitry and cause shorts. Ask me how I know? It happened. The guitar just stopped working during one gig and I had to switch to my backup for the rest of the show. When I got home and opened up the back for inspection, I found that two of the ball ends that I had been meaning to take out during the next stringing/cleaning session had gotten lodged in between the charging circuit board and the output jack, causing a short and frying the charging circuitry. The charge/output section is modular, so I figured a replacement would be fairly easy.
    I contacted Fender, and they were very kind and concerned, but couldn't send me the replacement directly; it had to go through a certified Fender repair shop. So I called my local one, who told me to bring the guitar in and they would coordinate with Fender on the fix. Unfortunately, the "fix" took 4 weeks, and turned out to be EXACTLY what I had supposed; Fender sent them a new charge/output section which they installed. Now, as a "kudos to Fender", there was no charge for this repair. 4 weeks is a really long time, though.
    When I got the guitar home, I immediately removed the new charge/output assembly, covered it with heat shrink tubing and reinstalled it. (once again, less than $5 worth of parts to avoid disaster) This will hopefully eliminate this from happening again with the charge/output section, but the main Fishman circuitry is still fully exposed inside, so there is still the potential for damage, so I'm seriously considering some Power Pins so the ball ends never have the potential to cause a problem. To me, it seems like such an expensive instrument shouldn't have issues such as these.
    Overall, I'm pretty happy with this guitar, and especially with Fender for stepping up with the free fix. I really do think it is WAY too expensive for what it is (basically a Telecoustic with Fishman Aura jammed inside), but it has become my daily driver. I honestly wouldn't mind having another as a backup, but not at that price! (or even the price of used ones)
    Hopefully, this may help others who have purchased or wish to purchase.
    Joe K, Brucedean, Mike M and 5 others like this.
  2. schmee
    schmee Doctor of Teleocity
    They are kind of interesting looking. But no way at their price point. I have had similar thin hollow guitars and they are never "acoustic guitars". As you say, they don't do either world that well. That's ok at minimal price. I'd take a vintage Guild Songbird, or S5CE etc any day over the Acoustasonic concept.
  3. Dan German
    Dan German Poster Extraordinaire
    Left of the Left Coast
    My Danelectro Convertible has that base covered. :p
  4. nojazzhere
    Foat Wuth, Texas
    Thanks for the info and heads up.....I hope maybe Fender is getting feedback from you and other owners, and taking steps to abate.
    That said, it sounds (by your own admission) that you are VERY hard on your instruments.....both in HOW you play and how often you play. Those habits naturally cause wear and tear. There are certain little "fixes", like the string tree, that I would think are "personal mods" that I would do on any guitar. I'm an inveterate modder anyway, so I don't expect to buy a guitar off the rack that didn't need something.
    Again, thanks for posting, and truly hope Fender is listening......;)
  5. tele_pathic
    tele_pathic Friend of Leo's
    St. George, UT
    Initially, I was intrigued by these guitars. Until I actually played a couple. The first was kinda "meh" and at $2000, uninspired. Also, I was a bit surprised at the less-than-stellar-especially-for-two-grand workmanship. The second one I played into an acoustic amp: It fedback something tremendous and horrible. tried a different amp but same result, so no thanks, esp given the price
  6. Stu Cazz
    Stu Cazz TDPRI Member
    Spain
    I got a big gas attack when I saw them the first time. But sometimes it is good thing to have empty pockets. I still like the looks and would love to own one but it really is way to expensive.
    Also I figured out that I already own a fantastic Tele and a Mooer Acousticar pedal, wich give me pretty much everything I need to swich quickly between sounds.
    Big thanks to the op for all the info, and nice to see that despite of the problems you're still enjoying yours.
  7. ukepicker
    ukepicker Tele-Afflicted
    Great review and objective, real-world observation.
    Thank you for this!
  8. Donnie L
    Donnie L TDPRI Member
    Louisville, Ky.
    Great Post ... I do know Fender is having a tough time with production of this guitar. My Sweetwater rep called me almost 4 months later saying they got a few ... I passed on it ... Price needs to come down and "adjustments" need to be made as this thread adequately shows...
  9. hotraman
    hotraman Tele-Afflicted
    Camas, WA
    Wow!! Great review and insights.
    Thanks for the pictures and details.
    I went through the hybrid guitar hole with a Taylor T5 Koa that I bought new.
    Same observations regarding the tone. I believe the same guy who was a part of the T5 design team, works at Fender and designed this.
    At the price, I wouldn't go for it.
    Not to mention your hassle with the electronics, makes me weary of buying this guitar.
    I'll stay with what I have been using: my Gibson J45 and a Telecaster.
  10. beninma
    beninma Friend of Leo's
    Earth
    Great post.. what is so weird about this guitar to me is I have this feeling you could stick those electronics in a $200 solid body Squier and it'd sound almost the same.
    From what I can tell it's all Fishman magic. And it sure is expensive.
    The Taylor T5s are pretty much the same thing.. Fishman magic IIRC. It sounds like they have some issues too, but I'd be the workmanship is quite good on those. Still it sounds like they have electronic issues occasionally.
  11. beninma
    Earth
    I think it's more that they're both Fishman collaborations. The T5 being an older version of it. They are both basically computers/modelers inside the guitar. My guess is it has a lot in common with the Fishman Aura preamp/pedal setup.
    It makes me curious to try a regular Tele through an Aura pre-amp. AFAICT if you had a pedal board the Aura would be compelling vs a T5 or an Acoustasonic.
    Brucedean likes this.
  12. backporchmusic
    backporchmusic Friend of Leo's
    Yeah, I was going to say: Lower end Takamine a/e ($250 used) --> Fishman Aura floor pedal (120 used)--> there you go.
  13. Brucedean
    Brucedean TDPRI Member
    Milwaukee
    Great write up!
    Thank you spkguitar!
    I bought one the other day, and I am surprised to hear a faint 60hz hum from the “noiseless” tele pickup. When turning the guitar volume down, the hum goes away. Only on mag settings, not on acoustic settings. Have you had such an experience? If this is normal, I can deal with it, after all, my other teles hum.
    My expectations however from a noiseless pickup was no noise. For example,
    I have a std tele with Fishman Fluence, pickup is dead silent.
    So how noiseless is your acoustasonic tele?
  14. Mike M
    Mike M Tele-Meister
    I had one for 6 months, and returned it for full refund because the truss rod was broken.
    I wanted to love the guitar so much, and playing it was fun (especially late night unplugged, just sitting on the couch, sue me), but in the end it didn't do acoustic or electric really great. Jack of all trades, master of none kind of thing.
    Also I never complain about price, especially for a product I fall in love with, but this really should be in the 1k range.
  15. Willy-son
    Willy-son TDPRI Member
    NJ USA
    A guy in my band has one. I can’t really say much about how they play because I’ve never had an interest in playing it. I’m not sure what Fender was going for, but I can say I hate it when he plays that thing. It’s not good as an acoustic or an electric. It sounds awful on doing either. JMHO for what it’s worth.
