Bob M.
Mr. Sparkle,
With a 350-0-350 output power transformer, you'll need to put your electrolytic filter caps in series. I'd recommend using 100uf @ 350 volts. Two of these caps in series will yield an equivalent of 50uf @ 700 Vdc. Please make sure to use the bleeder/balancing resistors. Copy a SF Twin Reverb schematic and you'll be fine. With any sort of steel guitar, you'll want a very stiff filter, use the same as above on the screens. Then, depending on the B+ on the PI and the preamp plates (which I don't know here), I'd probably suggest single electrolytic [email protected] Vdc. Axial electrolytic caps at high voltages are now getting really expensive so in a homebrew amp, I'd probably opt for radial caps to save money.
For steel guitar, consider using a solid state (diodes) rectifier. Steel guitar amps have more in common with keyboard applications or bass guitar applications than most guitar amps. You'll want a stiff power supply with not very much sag. In my amps, I have this rectifier choice on a switch so I can use either type of rectifier, depending on the circumstances at hand. More likely, you'll be using the solid state option most of the time.
Fender placed the standby switch in different places in the filter string in different eras of designs. Sometimes, the 1st filter is on the hot side of the standby switch with all subsequent filters downstream of the standby. Other schematics show all filters downstream of the standby switch, depending on the era of when the amp was built. With this second design, sometimes you'll get a noticeable 'thump' when switching from standby to play.
If this amp is dedicated to steel guitar use, consider using 4x 6L6 power tubes. You might be very glad you made this design choice, especially when playing outdoor gigs where the extra power of 4x power tubes is frequently needed for a clean sound. You also can incorporate a switch in your design to standby two of those power tubes so you have the more familiar Vibroverb power amp compliment. I also do this on a few of my amps and it works well.
Good luck, have fun,
Bob M.
Bob M.
