mistersparkle
Edit: I'm embarrassed that I accidentally attached the only AB763 schematic that doesn't reflect the query in my original post below (the Vibroverb schematic). I'm calling my build a "Vibroverb" clone only because I'm planning to use a single 15" speaker. Please refer to the now-attached Vibrolux schematic for reference to my cap voltage rating question stated below.
I'm in the process of building what basically amounts to a Fender Vibroverb clone, and I note that in all of the AB763-based schematics the five 16uF filter caps are all rated at 450VDC. Meanwhile, I also note that all the amps using 2x6L6 output tubes in this circuit have power transformers with 350-0-350 secondaries. The rectifier tube is a 5AR4/GZ34 with relatively low voltage drop, and two of the five filter caps are placed in front of the standby switch (in parallel, not series as is done in some later Fender circuits).
Everything I know about electronics tells me that, if the standby switch is opened, the filter caps in front of the switch will charge up very close to the peak of the AC voltage being applied, which in this case would be about 500V, give-or-take. Am I wrong, and if not, how did Fender get away with 450VDC rated caps? And if I'm right, should I build my amp with a pair of, let's say, F&T 80uF/450V caps in series (with balancing resistors, of course) for the reservoir? Btw, I already have the 350-0-350 PT (Mercury FDP-20) and I don't really want to lower the B+. And no, I'll probably never use the standby switch, but still....
