fender 2018 Player tuner replacements
Discussion in 'Stratocaster Discussion Forum' started by vishnu, May 4, 2019.
  1. vishnu
    vishnu Tele-Meister
    scotland
    My Strat has the stock standard tuners installed and i was a wonderin' if the Gotoh vintage aftermarket jobs would fit in there at all?
  2. Dismalhead
    Sacramento, California
    I had some old tuners from a US Strat and figured I'd replace the ones on my MIM with them. As I did it I realized they were pretty much identical. What's wrong with your old ones?
    Gotoh makes quality hardware. Size-wise, you gotta take one off and measure the hole.
    nojazzhere likes this.
  3. vishnu
    vishnu Tele-Meister
    scotland
    no reason other than i LOVE the look of those small button tuners :)
    I was hoping that someone had already tried the swap and could have enlightened me
    Thanks guys
  4. John C
    John C Friend of Leo's
    Kansas City
    The Gotoh vintage-style tuners would require a little surgery - you'll need to drill some guide holes in the back for the screws that hold them in place. You'll also need to get what are called "conversion bushings" - the holes for the modern tuners are a larger diameter than the holes for a vintage tuner, and the bushings that come with the tuners are for the vintage-sized holes. The conversion bushings are thicker so they fill the larger hole.
    But I would suggest getting a set of Fender's new ClassicGear tuners - these come stock on the American Performer series (the replacements for the American Specials). They look like vintage Klusons but they mount like modern tuners - they have the same 2 guide pins as the stock tuners on the Player series, and use the same-sized screw-down bolt on the face of the headstock as the stock tuners. Plus they have the modern 18:1 ratio instead of the vintage ratio (12:1 or 15:1 - I can never remember). Vintage look, no-hassle installation, modern tuning capabilities. I have an American Performer Mustang, and mine have been rock solid in terms of tuning stability.
    Here they are on Fender's website:
    https://shop.fender.com/en-US/parts...s/classicgear-tuning-machines/0990802100.html
    G.Rotten and nojazzhere like this.
  5. vishnu
    vishnu Tele-Meister
    scotland
    Wow, thanks for that John.....that looks GREAT! will look into it :)
  6. vishnu
    vishnu Tele-Meister
    scotland
    John, you sayin' they are drop in replacement with no work required?
  7. G.Rotten
    G.Rotten Tele-Holic
    CoolsVille
    They look drop in to me.
    I'm glad you started this thread because I didn't know those existed. I will likely give those a shot a some point. Like you, I prefer the vintage button/split shaft tuners, the typical vintage tuners can be made to work, but not without irreversible modification.
  8. John C
    Kansas City
    Yes - when I first got the Mustang I contacted Fender Consumer Relations about those tuners (I still had a Player series Tele at the time and was considering putting them on the Tele). The Fender rep confirmed that these are drop in, no modification replacements for Fender's standard tuners.
  9. Tuxedo Poly
    Tuxedo Poly Tele-Afflicted
    Merseyside UK
  10. vishnu
    vishnu Tele-Meister
    scotland
    Thanks John and Poly.....gonna get a set :)
  11. Paul45
    Paul45 Tele-Meister
    Thanks for that info John, I never knew those existed!
    Going to get a set for my Coronado
  12. Paul45
    Paul45 Tele-Meister
    Quick update. I can confirm that the classicgear vintage tuners are drop in replacements. Just put a set on my Coronado, they look so much better!
    Before...
    After...
    vishnu and Jsil13 like this.
  13. vishnu
    vishnu Tele-Meister
    scotland
    class :)
  14. DougM
    DougM Friend of Leo's
    Honolulu, HI
    I have a Performer Strat (my avatar) and those new tuners are awesome
