Febder new gen amps
Discussion in 'Amp Tech Center' started by 24 track, Sep 20, 2020.
  1. 24 track
    kamloops bc
    I've noticed an issue with some of the newer style Fender amps design flaws
    1) they use IC ( brand name) high voltage capacitors ( under the dog house and on the PC board ) that seem to leak quite frequently and early in their life cycle and /or create a ton of noise ( I always use F&T caps as replacements)
    2) there are 2 white ceramic 5 watt wire wound resisters soldered very close to the PC board that get very hot , discolor or burn the board and damage the associated components and possibly lift the traces of the board.( all that needed to happen here is elevate these resisitors off the board during installation)
    3) I have had 3 amps so far that have had cold soldered connections through out the amps and sloppy component placement on the board ( pins not pushed into the board fully creating further performance issues)
    4) the models I've had so far all seem to have similar issues
    A) 65 Twin BF reissue
    B) 68 custom twin
    C) Roc Pro
    D) Hot rod Deluxe
    E) Super sonic 22
    some thing to be aware of in general not every tube amp fails the same way , its just a pattern I noticed so far , this just an observation on my part
    Appearently my computer had a cold and spelt Fender as Febder! LOL:lol::lol::lol::lol:
    Digital Larry and nojazzhere like this.
  2. Deeve
    Deeve Poster Extraordinaire Silver Supporter
    Ballard
    Febder - I thought that was a dodge on mods, for an unknown reason
    24 track likes this.
  3. 24 track
    kamloops bc
    no my fingers havent woken up yet!
  4. timfred
    timfred Tele-Meister
    Northern CA
    Out of curiosity, what were the max voltage specs on the IC caps that you have seen? F&Ts are usually 500V I think?
    Personally I have no issues with IC caps when correctly sized. Running a 450V cap in a 420V B+ amp is not a recipe for longevity.
    When I have a choice (like when reliability is more important than vintage correctness) I try to stick to name brand caps used in high volume consumer electronics. These days that’s usually radial leaded caps from Nichicon, UCC, Panasonic. If I have B+ over 400V then I’ll put two 300V+ caps in series with bleeder resistors for the first node.
  5. 24 track
    kamloops bc
    I have been able to match the the cap voltages used in the amps exactly with F&T's and the results have been dead quiet,
    IC caps tend to leak at a an earlier stage and get very noisy in the process for some reason , very weird
    22uf , 500Volts
    220uf,300volts
    47uf, 500volt
    100uf, 100volts
    dont forget these are in the newer style fender PCboard amps not the turret board amps ,
    this is the issues I've been working on these amps
