TommyGunz
I played one of those amps for the first time recently and was impressed!Tim v3 and an old Bad Cat Black Cat 30. Killer. I personally need a reverb in the chain but really, I don't need anything else.
I like the sound of that. I have a Bogner Atma (60's, 70's, and 80's Marshall circuits) and a Fulldrive 3 as well. Imma try that combo out!Marshall JMP Master lead II with a Fulldrive III to kick its butt into screaming dirt
I forget ( a buddy of mine I haven't see in years has the TS9DX and loves it),Deluxe Reverb and Ibanez TS9DX on Turbo mode.
The Turbo mode adds big clean bottom. It's like a big 4 x 12 Marshall cab! I dislike the typical 808 style 'big mid hump' except for leads only. I use it mainly with the gain real low then adjust the tone control and volume to suit. But I have used it for more gain also and it's good, it's just that I run 3 OD pedals and use an OCD for higher gain stuff. I can switch to a more transparent OD, the OCD or the TS9DX with one push using a switcher.I forget ( a buddy of mine I haven't see in years has the TS9DX and loves it),
What does Turbo mode do? And where do you set your Gain/Drive knob?
* just curious!
When I've used Tube Screamers in the past (now a Joyo), I actually had the Drive UP, ( rather than SRV way) as I liked the distortion/grind from the TS, and could not run my amps loud enough alone to overdrive...
