Faux "ebony" binding?
Discussion in 'Tele Home Depot' started by blackbelt308, Jul 13, 2018.
  1. blackbelt308
    blackbelt308 Tele-Holic
    Columbus, Ohio
    OK, looking for some ideas here...
    Having successfully created faux wood binding on several builds including this spalted maple top beauty, I have another idea in mind. Possibly a stupid idea! :)
    For a new build, which will have a bookmatched Ambrosia maple top over mahogany - and no burst - I want to create the appearance of ebony binding on the edge of the maple top. That would give me a black line of contrast between the slightly amber top and the Heritage cherry finish of the mahogany.
    Has anyone tried something like this? Thinking I could accomplish it with lots of careful masking and spraying black-tinted lacquer on the edge, but there may be a more elegant approach.
    Thanks in advance!
    Rick
  2. Finck
    Finck Tele-Afflicted
    São Paulo - Brazil
    I think it will be easier to put a real binding, black or dark wood. Anyway, sure it will be a nice touch in a light colored top.
    If you decide to paint, probably an airbrush will make your life easier than use a spray can or even a gun. Don't need to be an expensive one, just has to allow you to go reasonably narrow.
    fasteddie42 and eallen like this.
  3. stormin1155
    stormin1155 Tele-Meister
    Iowa
    I'm with Flinck…. Stew-Mac sells Dremel binding routing attachments, and they are not that expensive.
  4. Ripthorn
    Ripthorn Tele-Afflicted
    Austin, TX
    I've tried something similar before and it didn't work out all that well. Even using high quality tape and finish, the line wasn't as crisp or clean as real binding will be. However, if the curves make for difficult binding, I understand your desire. You can try on scrap with your chosen materials, but it's not the most straightforward operation.
  5. Old Tele Hack
    Old Tele Hack Tele-Meister Silver Supporter
    Virginia
    I can't answer the binding question, but, wanted to say that THAT is a gorgeous guitar! I love the colors, the neck pickup surround, eveerything about that looks great!
  6. blackbelt308
    Columbus, Ohio
    Thanks for the kind words regarding my guitar! Appreciated!
    Yeah, I think you guys are probably right: it is time to delve into my first attempt at binding!
    Thanks,
    Rick
  7. Macrogats
    Macrogats Friend of Leo's
    Auckland, New Zealand
    Can't advise on the binding issue - but dude, that is one beautiful guitar!!
  8. TRexF16
    Tucson
    I have an almost identical body in work - bookmatched ambrosia, natural with just a hint of darkening fade envisioned. I was just planning on regular black binding. No reason your idea wouldn't work, but it's just that sprayed on binding seems more associated with cheap guitars as a labor saving step. I'm with the crowd that recommends the real thing. It could actually be done with real ebony or maybe blackwood, but that would be pricey and possibly fraught with swearing when a carefully prepared thin ebony strip breaks. For the third time. But if you boiled them I bet you could make it work.
    Rex
  9. eallen
    eallen Tele-Afflicted Silver Supporter
    I am generally with everyone else on the headache.
    At the same time, if I had my heart set on it I think it can be done. I would seal the area first and sand for a smooth finish for quality pistripe tape to adhear to. Spary on a light coat of clear over your pinstrip to seal the edge. Follow with your dark color as dry as possible. If any color seeps under the edge I use a utility knife edge to scrap a fine line.
    Every attempt at something new is an education for the future.
    Eric
    old wrench likes this.
  10. Finck
    São Paulo - Brazil
    I've never applied real wooden binding on guitar (actually I've never applied any kind of binding by myself...) but, working on wooden ship models, there's a trick to conform strips of wood: a cheap hair straightener. It works like a charm, no matter how hard the wood is. You just need to soak the strip little with water and pass it between the surfaces of the straightener. Instant curves!
    RodeoTex, NilsZippo, Mat UK and 2 others like this.
  11. eallen
    Very cool insight! Never thought of hair straightener! Something to remeber.
    Erix
  12. Maricopa
    Maricopa Friend of Leo's
    Phx, AZ
    Take it from someone that's actually done ebony binding....use black plastic. Once the finish it on it will look the same and you'll save a lot of money and curse words
  13. Barncaster
    Northern California
    You could probably cut your hardwood binding using using a CNC. Helmut has probably worked it out.
  14. Tomasi
    Tomasi Tele-Meister
    Finland
    eallen likes this.
  15. printer2
    I usually see people's guitars and say, 'That's nice, I should do one some day.' I very rarely think, 'I want that guitar.' Saved the picture for future drooling.
    While not a method for your madness I had some black ABS binding on a body and I scuffed the surface with sandpaper. It gave a reasonable ebony look.
  16. I_build_my_own
    New York
    Here is my humble view on faux binding of any kind: I admire everyone who can pull it off with crisp lines and no color bleeding through. I have never managed that. That guitar up there in the first picture is just amazing and the “faux” spalted maple binding adds to the perfection!
    I normally just put regular ABS binding on my builds for 2 reasons: A) cutting a binding channel is no rocket science (even I can do it!!) and B) a ABS binding in my eyes protects the corner way better than a wood binding, regardless if it is faux or real wood binding. Plastic is way more forgiving when something sharp attacks the corner and can get easier repaired than a nick/ding in a wood binding. I believe the inventors of binding had more than just adorning in mind. Just me thinking...:)
    LeftFinger likes this.
  17. I_build_my_own
    New York
    Naaa negative :(
  18. I_build_my_own
    New York
    Ohhh I like this!!!! I mean that resonator in Maricopa’ picture
