Fattening tone with a hair of dirt - what device works?
Discussion in 'The Stomp Box' started by udoering, Jun 19, 2016.
  1. Freethenoise
    Freethenoise Tele-Holic
    +1
    Gorgeous, toneful boost.
    davey77 likes this.
  2. davey77
    davey77 Tele-Meister
    Corona
    ...it's funny mine gives almost that same tone, but with a bit more gain very 3D quality tone!!!
  3. Televised
    Televised Friend of Leo's
    Portland, OR
    I think they all can get you there. Just depends what your ears prefer. I happen to use the EHX Soul Food, (inexpensive Klon clone), to get the job done and can recommend it as others already have.
  4. Coach56
    Coach56 One of the Boys
    Oak Park, IL
    I might suggest the Visual Sound Route 66 pedal. It contains both a booster based on the Tube Screamer circuit and a very nice compressor based on Ross/Dynacomp circuit.
    The boost can be set very clean or you can add some "hair" to it.
    What sets it apart is the bass boost on the TS side and a tone control on the compressor side. If I had to get rid of all but one pedal this would be the one I would keep.
    Check it out on youtube and see if it might fit.
    Best regards,
    Harry
    awasson and telemnemonics like this.
  5. gtrguru
    gtrguru Friend of Leo's
    Detroit Metro
    I have an EP Booster and Klone on my board. The Klone makes notes sing but the EP really fattens things up and adds some dirt.
  6. smithsonian
    smithsonian Tele-Meister
    San Antonio, TX
    I'm currently using the way huge porkloin. Some folks say it gets into Klone territory. I used to use the Fulltone Fat Boost 3, and it was great as well. Both can be found used under $100.
  7. awasson
    awasson Poster Extraordinaire Gold Supporter
    Vancouver
    In the mid 90's I got rid of all my pedals except for my late 80's Jim Dunlop Wah and my 1983 TS9 Tube screamer, which I put in a box and forgot about for 20 years. Just this week I picked up a few new pedals and dusted off the old ones. The TS9 Tube Screamer, with just a little drive and a little level doesn't change the tone of my tele; it just fattens It up a little and gives it a little dirt. Using the tone control on the guitar allows it to get nice and dark without getting muffled too.
    Even with the recent acquisition of a Boss DS1 (with the Kelley Ulta mod) and a Sans amp XXL pedal, the TS9 is still the best overdrive/distortion pedal I have.
  8. udoering
    udoering Friend of Leo's Silver Supporter
    near Cologne, Germany
    Again, thank you all very much for your inputs. The Route 66 seems to be a very interesting alternative.
    telemnemonics, Coach56 and awasson like this.
  9. Coach56
    Oak Park, IL
    So one fun thing you can do with the Rt66, first you set your compressor to give the overall volume level you want. This tends to balance the strings a bit, you want a bit of compression but not a big squish, depending how far you go this will also increase your sustain a bit.
    Now turn the compressor side off, turn on the OD side and set a nice thick tone, make it a bit louder then you want, figure this as your solo setting.
    Now turn both of them on, you should get that nice thick tone, but at the same level as just the "clean" compressed tone.
    You can toggle the OD on or off and the overall volume should be the same but the tone will change, or you can toggle the compressor on and off ( with the OD on ), the OD tone will be ( basically )the same, but the volume will increase and push the amp harder.
    Anyhow YMMV, but I do have a lot of fun with this pedal.
    Oh, one other thing, the buffer built into this pedal is supposed to be one of the better ones on the market, my board runs pretty quiet all in all.
    -H
  10. CAAD8N8
    CAAD8N8 Tele-Holic
    Ohio
    Emerson EM Drive thickens up the tone and can add hair. Also, the TC Spark mini booster for space saving
  11. TwangToInfinity
    TwangToInfinity Tele-Holic
    Twangville
    for me i would use a compressor and dail back the highs and dial up the bass or mids or whatever.
    i am of the opinion that distortions and all that make the sound tinyer
  12. Fiesta Red
    Fiesta Red Friend of Leo's
    +1000
    Fairly transparent overall, but the ability to thicken the overall sound...
  13. Tele295
    Tele295 Poster Extraordinaire
    Ventura CA
    Nocturne Brain
    Serenity23 likes this.
  14. goonie
    goonie Friend of Leo's
    Joyo American Sound, for the budget conscious tone hunter
  15. refin
    refin Friend of Leo's
    Florida Panhandle
    Soul Food,or Box Of Rock by Zvex...the boost side by the latter does a great job on my old tweed Bassman.
  16. smithsonian
    San Antonio, TX
    This is good advice.
  17. DaveKS
    DaveKS Friend of Leo's
    KS
    Might look also at the EQD Speaker Cranker, it's another 1 knob wonder from EQD, touch more breakup than Arrows. Cleans up on vol knob great too.
    VFE White Horse also works great here. It's as much preamp/drive as it is a optical comp with clean blend. Adding a touch of grit, bloom and sustain is where it's at its best.
  18. udoering
    Thanks to everyone who contributed here. I just ordered a Route 66, the combination of a compressor (I already had thought of one) and overdrive with the possibility to blend in the clean signal on both sides seems to deliver what I imagined. I will tell you about the outcome.
    CAAD8N8 and awasson like this.
  19. uriah1
    Around
    Tc spark boost with switch up position
    Modman68 likes this.
  20. howlback
    howlback Tele-Meister
    Los Angeles
    +1 RC Booster
    One-knobs are nice but having the gain, vol control help. I leave the EQ flat.
