fading nitro with UV
Discussion in 'Tele Home Depot' started by Dimitree, Jul 22, 2019.
  1. Dimitree
    Dimitree TDPRI Member
    Italy
    so I got a Jazz Bass body that I finished time ago with nitro Fiesta Red (no clear coat).
    Then I saw this guitar:
    and I fall in love with this faded fiesta red, so now I want this finish.
    If I understand well, when aging, clear coat would get the color more yellow, while this guitar turned towards pink, so I'd say there is no clear coat on this guitar and the fading is actually in the color coat. Am I right?
    Indeed I tried to spray some clear amber on my fiesta red, and the result is completely different.
    I guess I have two options:
    1) fading the color coat with UV lamp (I have some)
    2) cover the body with more coats using a mix of fiesta red and (maybe) olympic white.
    what do you suggest?
    I have a cheap air compressor so I don't know if it is good enough to finish a body. I used aerosol cans to finish the body in the first place.
    If you suggest UV lamp, how much time would it get, more or less?
  2. Freeman Keller
    Freeman Keller Tele-Afflicted
    I think a lot of it was the way old NGR alcohol soluble stains fade differently than modern dyes. Dan Earlewine has a recipe for Fiesta Red (its got a drop of yellow in it)
  3. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Often Fender put out Custom solid colours in the 60s with no clear coat. The 62 Strat below is Olympic White, which is acrylic and therefore barely darkened. It has no topcoat and Fender was known to out guitars out like that pre-CBS
    The pigment falls out of most red, and some blue and purple. Hank Marvin's salmon pink Strat was probably Fiesta, which is orangey-pink to start with.
    That offset guitar above is close to Fiesta Red when it's new. People think it's a blood red but it's not.
  4. rich815
    rich815 Friend of Leo's
    San Francisco Bay Area
    Remove the neck, all electronics, hardware, etc and put it out in the sun to “bake” for a few weeks. Rotate regularly. I did this with an Olympic white strat and it yellowed moderately but beautifully (I took it in at night to avoid dew and moisture). I left the pickguard in place so I could check progress. Now that said I live in the San Francisco Bay Area where it rarely gets over 80°F and I did it in the spring when the sun was not too harsh. I’m not sure I’d do it under a baking 90-100° summer sun as it might warp(?).
    Or refinish in the same paint but add some white to the paint mix to get the color you’re after.
  5. DaphneBlue
    DaphneBlue Tele-Meister
    Switzerland
    See we've got some love for shell pink here.
  6. ecoast
    ecoast Tele-Holic
    NWNJ
    I have a iced t lp that I often put in the sun to 'tan'...(fade)
    I have a piece of cardboard that covers the entire rosewood on the neck
    It does work. When I pull the poker chip off I can see how much darker it was...
    I have left it out in the yard, as well as in the window sunlight.
    Now somebody will post that the 'new' nitro doesn't fade... But it does.
  7. netgear69
    netgear69 Tele-Afflicted
    england
    The guitar in the picture has a white primer fiesta red looks a lot different with a white primer
    i have done a couple of fiesta red finishes with and without a primer the one without looked a lot darker maybe it is just a trick of the light
