F Hole Conversion?
Discussion in 'Tele Home Depot' started by KazPed, Mar 30, 2009.
  1. KazPed
    KazPed TDPRI Member
    Orpington, UK
    hey all
    I have a telecaster body i would like to use, but i wondered if theres a way i could give it an f hole, suppose convert it from a normal solidy body, to a thinline one? and how to do it? thanks
  2. kayarcee
    kayarcee TDPRI Member
    Brooklyn
    Plane about 1/8th of an inch off of the top, route out the chambers on the upper bout and lower bout (I'm sure there are a few templates in the resources section or in this very forum's archives for Thinline cavities), and then build a top out of 1/8th inch-thick maple/alder/spruce/rosewood/luan/plywood/mdf/chipboard/your wood here
  3. KazPed
    KazPed TDPRI Member
    Orpington, UK
    hmmm, so how difficult would this be for someone with limited workshop experience?
  4. jefrs
    jefrs Doctor of Teleocity
    Newbury, England
    Hi, KazPed.
    Assuming you've never used either a plane or a router before then, sorry, this is a bit of a no-no for a first job. If you really want a thinline then buy a thinline body. Otherwise you're looking at setting up a workshop for what may be a one-off job.
  5. KazPed
    KazPed TDPRI Member
    Orpington, UK
    well ive used a plane and a router before. and my school has a workshop and some experienced teachers! (who are also guitarists)
  6. Jack Wells
    Jack Wells Doctor of Teleocity Ad Free Member
    Albuquerque, USA
    First of all ......... 1/8 in is a bit thin for a top. Thinline tops are about 1/4 in. thick.
    Second, I would not take a hand plane to a guitar usless you are an expert in the use of such a tool. You could run it through a 13 in. surface planer. The smarter way would be to take 1/4 in. off the back unless you have a really nice bookmatched top that you want to use.
    Another option is do something like the following:
    ......[​IMG]
    This was done without any paint touch-up ........ hence the odd pickguard shape. Here's how I did it.
    Weight Reduction Plan
  7. KazPed
    KazPed TDPRI Member
    Orpington, UK
    wow man, that is amazing. how does it sound as a hollow body? or is the f hole purely for show really?
  8. boneyguy
    boneyguy Doctor of Teleocity
    victoria b.c. CANADA
    Yes, 1/8" is way too thin. 1/4" is more typical for a cap like that.
    That's a very cool design Jack.
  9. varakeef
    varakeef Tele-Afflicted
    Finland
    With a very limited wood working skills I hollowed one solid body like this:
    http://www.tdpri.com/forum/tele-tech/95975-yet-another-thinline-project.html
    It's in no way an example of how to do it, but I think it shows the amount of great hints and advising you get from here. There's lots of don'ts there, but it worked out well eventually.
    And I got some help with the planing of the back, but basically it was a project of how do a hand router work. :D
  10. jefrs
    Newbury, England
    KazPed, if you've got access to the workshop, tools and tutors, then off you go!
    I might be inclined to do the routing before planning off 1/4-in or more, that way a template can be screwed firmly to the top, also less planning to do, especially if you have a big bench planner or surfacer. A carved-top maple cap might look real pretty.
