joulupukki
Rather than bog down an already lengthy build thread (here) I figured I would ask specifically for some help in a new thread to help me diagnose what might be going on.
I am getting some sound out of my new build but it is really really low volume and I’m not sure what to look for/test next. Here are some things I’ve tried:
B+: 410V
B+2: 407V
B+3: 375V
B+4: 370V
Rectifier Heater: 5VAC
All other heaters: 6.3VAC
(heaters are right on the money)
Bias supply: 55VAC
Rectified bias: -47.1V
Bias after bias pot: -39.8V
V6 OT Plate to B+ Resistance: 33.3 Ohms
V7 OT Plate to B+ Resistance: 40.8 Ohms
Attached is my schematic and layout diagram.
Any idea on what sounds suspect or what I should look into next?
- Tried the tubes in a different amp. All good.
- Tried the speaker with a different amp. Good.
- Power tubes are biased at 55%
- This amp has a power amp input and so I’ve tried injecting sound from another amp’s SEND (preamp) and the same exact problem happens so I think I can safely say that the issue is isolated to the Phase Inverter and beyond, right?
- Removed the NFB temporarily just to see that’s not causing any issue
- Speaker output ground
- Verified the capacitor and resistor values of the phase inverter and output section
B+: 410V
B+2: 407V
B+3: 375V
B+4: 370V
Bias supply: 55VAC
Pin 1 | Pin 2 | Pin 3 | Pin 4 | Pin 5 | Pin 6 | Pin 7 | Pin 8 | |
V1 7025 Preamp | 254 | 1.7 | 256 | 1.7 | ||||
V5 12AT7 Phase Inverter | 391 | 0.449 | 10.53 | 369.3 | 0.45 | 10.53 | ||
V6 6V6 Power Tube | 409 | 408 | -39.74 | 408 | 18.3mV | |||
V7 6V6 Power Tube | 409 | 408 | -39.82 | 408 | 18.3mV | |||
V8 GZ34 Rectifier | 410 |
