Extension cabinet speaker.
Discussion in 'Amp Central Station' started by fasteddie42, Jan 14, 2020.
  1. fasteddie42
    fasteddie42 Tele-Holic
    Tip of the Mitt
    I own a greta, pro junior (stock jenson?), and a PRRI (celestian g10 greenback)
    Greta through the pj's 10" gets the most use by far.
    All 10" speakers and 8ohms.
    I'd like to purchase a 1x12 or 2x12 extension cabinet wired at 8 ohms (mostly for a dedicated greta cab).
    I'd like to be able to use the cab with my other amps too.
    I have no experience with selecting speakers.
    What speaker would you recommend for a greta/pro junior/prri extension cabinet?
    2 watt amp and two 15 watt amps, any sort of ballpark wattage or power handling I should consider?
    Any advice is appreciated
  2. JustABluesGuy
    JustABluesGuy Friend of Leo's
    Houston, TX
    I have been using a 1X12 with an Eminence Reignmaker, and it sounds great with the Greta.
    The variable efficiency is quite handy as well.
  3. radiocaster
    europe
    You want to be able to turn up the Greta at least somewhat? Greenback.
    You want to bust some eardrums and damage your hearing? Vintage 30.
    Milspec likes this.
  4. fasteddie42
    Tip of the Mitt
    I use the greta from whisper quiet to wide open.
  5. radiocaster
    europe
    I haven't been able to crank my Greta all the way with a 10" cab, only with an 8" cab. Too loud with the 10", but it's not a Greenback.
    It does have earlier breakup but it's still loud with big cabs. I do like it with an attenuator.
  6. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Greta stipulates 8 ohm min so depends what you want. I'd pick a speaker that suits your other amps. The Greta is a bit Tweedy in character.
    JustABluesGuy likes this.
  7. VintageSG
    Yorkshire
    Rather than a 1 or 2x12", give some serious consideration to tracking down a 2x10" cab. There's something so right about the sound small-ish amps make through a 2x10".
    As for speakers, I'm a Jensen fanboi, so I'd go with a pair of MOD 10-50 or Jet Falcon 10". They're not spectacularly efficient, and they sound wonderful ( to me )
  8. Telecastoff1
    Telecastoff1 Tele-Holic
    Minnesota
    I have a Fender 1x12 cab that I loaded an 8 ohm EVM12L into. That cab/speaker sounds great thru any amp I've ever played thru....from whisper-quiet to house-shaking-loud. For me, it's the Swiss Army Knife of speaker/cabs.
    Tonemonster likes this.
  9. fasteddie42
    Tip of the Mitt
    I don't quite understand speaker stats...
    I don't know what would be overpowered/underpowered (I understand that 15 watts and under isnt wildly powerful).
  10. guitarmikey
    guitarmikey Tele-Holic
    Bucharest
    I made a DIY cab for 10" Ragin' Cajun, also found an older amp that died, and changed it to a 12" cab. Greenback 12H goes great for me next to RC (for Pro Jr IV, Micro Terror, Vox MV50 AC..., Super Champ X2H).
    Or you can check harley&benton cabinets (thomann)
