Experiment with pre-heating the guitar before nitro
Discussion in 'Finely Finished' started by Slippery Jack, Oct 19, 2020.
  1. Slippery Jack
    Slippery Jack Tele-Meister
    Southampton, UK
    I am battling with humidity at the moment, it's been about 62% for the last week or so. I experimented on a bit of plywood and found that if the wood was cold, I would get bloom. If I heated the wood in front of a fan heater first, it would give a decent finish. I tried it on the guitar and it worked.
    Did I get lucky, or is the condensation from the damp air onto the relatively cold body, with the cold spray from the can, that is giving the bloom? Has anyone else tried pre-heating the guitar? Perhaps someone else can give it a go and see if it works for them?
    That Cal Webway likes this.
  2. Dano-caster
    Dano-caster Tele-Meister
    Snore'n desert
    I haven't had that problem so far with humidity but you might want to pre heat the can as well.It sprays better and may help your situation .
    photondev likes this.
  3. Matthias
    Matthias Friend of Leo's Gold Supporter
    Where are you spraying?
  4. Slippery Jack
    Southampton, UK
    Near Portsmouth, UK.
  5. Matthias
    sorry, I meant set-up wise - inside/outside? Garage?
  6. Slippery Jack
    Southampton, UK
    I'm spraying in the equivalent of a garage. I set up a heater and dehumidifier hours before I'm ready to go. Then I heat the guitar in front of the heater until it's warm to the touch. Observing my test piece, I saw the bloom arrive in the finish after it was sprayed, which made me think that the bloom was in fact water vapour condensing onto the cold surface of the wet paint. So I thought, keep the surface warmer than the surrounding air (water vapour) and the water vapour won't condense.
    I haven't pre-heated the can yet, I'll give it a go in a few days for what, hopefully, will be the final pass. I didn't previously pre-heat the can as I thought that the temperature drop when the pressurised liquid changes to a gas would be so great that the effect of heating the liquid would be insignificant. However, I'll give it a go.
    As you can all probably tell, I'm a complete novice at this and this is a one off project, and if I'm completely wrong about any of this please say so. I'm experimenting and reporting, not instructing.
    ps You might have guessed that I have a science background.
  7. Tommyd55
    Tommyd55 Tele-Holic
    Southern Louisiana
    I am sure you already know that when they say heat the can of Nitro they mean by putting the can in the sink with warm or hot water..
    just thought I'd throw that in ..
