Evil Twin
Discussion in 'Amp Central Station' started by rushman, Jan 17, 2020.
  1. rushman
    rushman TDPRI Member
    cygnet
    I have a blackface Evil Twin that I had rebuilt by a fastidious tech with new old stock correct capacitors,caps,etc.It had been sitting in a chook shed for years.It is an amazing amp.But there is a problem that has mystiefied us.The reverb doesn’t work unless you have an effects box plugged into the front and the effect doesn’t have to be on for it to work.Plug a guitar straight in and it’s no go.Before we pull it all apart can anybody shed any light on this.This applies to both inputs.
  2. cometazzi
    cometazzi Tele-Meister Silver Supporter
    Das Land von Käse und Bier
    First question: Does it make a difference if the FX box is true-bypass or has buffered switching?
    That could give up a clue.
  3. rushman
    cygnet
    I don’t have a buffeted effects unit( is the OCD overdrive?i have one).Not sure why this would make a difference.Just seems strange that a straight lead from guitar to amp gets no reverb.But plug a box in and there it is with full adjustment on the control panel.
  4. Milspec
    Milspec Friend of Leo's Silver Supporter
    Nebraska
    Using the same instrument cable? Have you tried using the cable from the OCD to the amp as the instrument cable from guitar to amp? I can't think of any other reason why that pedal would make any difference....just a bad cable?
  5. Cysquatch
    Cysquatch Tele-Holic
    Grovetown, GA
    Try it with the pedal in the chain, but no power supply or battery. Not sure what this would mean, but seems like there's some wild stuff going on here, so might as well try everything.
  6. Wally
    Weird problem there. I have no thoughts on that.
    I will observe that using NOS electrolytics is not advisable. They go bad with age in or out of a circuit......and probably last longer if they are in-circuit and have current run through them at least once a week.
  7. rushman
    cygnet
    Sorry been busy.Thx for suggestions guys but we have tried everything.Tech(who is fastidious)is going to pull it apart and check.
  8. rushman
    cygnet
    As far as using NOS goes I may have been wrong describing.I meant he sourced all the components correct for that model.
    Wally likes this.
  9. Wally
    NOS = New Old Stock....meaning it has been sitting unused since it was built. Like dry cell batteries, that does not work for electrolytic capacitors. I felt almost certain that your tech would not use such parts.
  10. rushman
    cygnet
    Fixed by my tech.He did explain it but I am really not that tech minded but it was something to do with a wire going to the reverb tank.Also regarding the NOS query he used parts of the same specs as original not stuff that had been lying around for years
  11. '51 geezer
    '51 geezer Tele-Meister
    Arkansas
    How do you know if you have an "Evil" Twin. I'm assuming that comes from the "The Twin" series of amps. I have a chance to buy a "The Twin" for 500 USD. The listing says it's an "Evil" Twin. It's blonde, I think, may be tweed. It only has one red knob. The guy also says it has a 25 watt and a 100 watt setting. This, I've never heard of on any Twin, but, I'm no expert.
    Is this anything to get excited about?
