Evertune bridge
Discussion in 'Tele-Technical' started by cousinpaul, Sep 23, 2020.
  1. cousinpaul
    cousinpaul Friend of Leo's
    Nashville TN
    A customer recently brought me a Les Paul Studio with one of these installed. I've never seen anything quite like it. Evertune makes them for tele, strat, Gibson, etc and also markets a number of popular guitars with the system factory installed. Their website says the Evertune system will keep the guitar in tune under any and all conditions. They are pricey and crazy invasive. I must admit, the LP did stay in tune well, but that could also be attributed to a good set-up.
    matty428 likes this.
  2. matty428
    matty428 TDPRI Member
    California
    I think the concept is pretty badass. I just don't think it's newb friendly. And as a newb myself, I'd never have the guts to rout the cavity to house the thing.
    gregulator450 likes this.
  3. Collin D Plonker
    Collin D Plonker Tele-Afflicted
    Delaware
    Please elaborate. What makes it special?
    nojazzhere likes this.
  4. rangercaster
    Knoxville TN for now
    I don't like the idea of carving up a perfectly good guitar, but I might consider it...
    You certainly destroy any resale value, so I might try it on an Epiphone or other cheapo...
    But then the bridge would be worth more than the guitar...
  5. cousinpaul
    Nashville TN
    From what I've read, it uses spring tension to return the string to a pre-set pitch. Seems like the nut would still be a factor but what do I know. My guy wanted me to remove it but it would leave a mess in a critical area.
    I think the owner will either keep it or sell as is. Too bad. The LP is finished in vintage white and a real looker. Good player,too.
  6. nojazzhere
    Foat Wuth, Texas
  7. Collin D Plonker
    Delaware
    Seems like a spring pulling backwards would counter strings catching at the nut. Interesting concept, but the routing is an issue. Maybe better for a build than a refit.
  8. AJBaker
    AJBaker Friend of Leo's
    Switzerland
    I've seen them, I think they're pretty silly, but you're bound to see a shill turn up here soon. Every thread about this bridge eventually has a proponent show up who only ever posts about this bridge.
  9. JJLC
    JJLC Tele-Holic
    Midwest
    IMO don't waste your time & money on an Evertune; a good guitar should stay in tune, period.
  10. gregulator450
    gregulator450 Tele-Afflicted
    The Dry Side
    I have yet to play one myself, but I [think I] understand the concept. Each saddle is on its own spring loaded system, and once set up, the spring system compensates for the changes in the string that could cause it to go out of tune. It can be set up to accommodate string bends, or it can cancel out string bends. I have heard it described as "a separate Floyd Rose for each string", but I don't think that's terribly accurate.
    It's really popular with modern and extreme metal guys where aggressive playing styles and machine-like precision are valued (often more than the human element). If, for example, you hit a string with the pick hard enough to bend it out of tune, or if your playing style pushes a guitar from being in tune to out of tune through the course of a song, the Evertune stabilizes each string and keeps it in tune. It seems to have the most value for guys working in the studio on modern heavy music.
    Schecter, ESP, and Jackson all offer versions of their models with Evertune bridges, so that should give a good indication of the target market. I see that Fender has an Evertune Strat and Gretsch has a solid body model coming out soon with it installed.
    It is an invasive retrofit, similar to installing a strat type vibrato or a Floyd on a hardtail, yet it does exactly the opposite of a vibrato. I used to do a LOT of tech work for modern metal guys, so I figured I should pay a bit of attention when it came out. I think there are situations within its target market where it makes a lot of sense, but it's a niche product for sure.
    Collin D Plonker likes this.
  11. gregulator450
    The Dry Side
    I would go to your nearest guitar big box store and try a guitar that comes with a factory-installed Evertune. If you like how it works, Evertune can provide you with a list of shops authorized to retrofit, and I believe they will even sell you the routing templates if you're brave enough to do it yourself.
  12. gregulator450
    The Dry Side
    I am too young to know what the initial response to Floyds and Kahlers was, but I would bet that in 10-20 years the Evertune will be considered as essential to a specific type of player as the locking systems are today.
  13. Jim_in_PA
    Jim_in_PA Tele-Afflicted Silver Supporter
    SE PA near New Hope PA
    Darrell Braun recently did a YouTube review video of this bridge and it was eye opening. It does what it says it does. Sadly, it's really not a DIY type product, but I don't think their services are unreasonably priced for folks who really would benefit from the EverTune setup.
  14. gregulator450
    The Dry Side
    Just watched the video. He did a better job of explaining the EverTune than EverTune ever has.
    Jim_in_PA likes this.
  15. Injam
    Injam Tele-Meister
    Georgia
    There is a video on Andertons’ TV. They are playing an ESP that had one installed. It new the difference between a bend and it being out of tune. They were able to do a slow bend that made it try to adjust the tuning.
