Fendereedo
Next time I set up, sure.Can you post a picture of how you use them to measure string height?
This is a good list but IMHO Unless you really really want to learn the whole process for building a neck I would skip the fret leveling and nut files. Things can go very bad in a hurry if that gets done poorly.In terms of tools, the list can be quite extensive depending on how deep into setup you want to go. For example if you just want to set the string heights, you just need a string height gauge and a hex key to screw driver to adjust the saddles.
A basic setup includes the following. (with tools in brackets)
- Inspect the frets (Fret rocker) - if levelling required (notched rule, sanding beam, crowning file)
- Measure and adjust the relief (Feeler gauge, nut wrench/hex key)
- Measure and adjust saddle height (String height gauge, radius gauge)
- Measure and adjust nut height (Feeler gauge, Nut files)
- Adjust the intonation (A "very" good tuner, screw driver)
Hope this helps, but I highly recommend you read through Freeman Keller's post linked above for far more detail.
Yes, as I mentioned several times before, a string action gauge is one of the most valuable measuring tools on my bench. I have the StewMac version but they are all good.Crap, no wonder you questioned my post, I meant to post this one instead, duh!
Ha!Yes, as I mentioned several times before, a string action gauge is one of the most valuable measuring tools on my bench. I have the StewMac version but they are all good.
I don't use it for nut slots, I think feeler gauges are much more accurate there, but it works really great for action farther up the neck. In a pinch it doubles as a fret rocker.
However I've got to admit I was looking forward to learning how to use calipers.
