rze99
I’ve read several opinions on forums that talk about neck stiffness of some Strats and a few that mention it specifically regarding the EJ Strat.
It’s obviously a thing because enough people mention it but I’m not sure what it is. I bet if you were to play mine, you’d find it is the same as the ones you’ve had. Maybe I haven’t played enough Strats to know the difference. I’ve had 4 Strats in the same period you’ve had 200 so I’m sure you’re going to have a different level of knowledge of them.
I should get it Saturday. I see that the former owner has kept it as intended in terms of the trem arm and block.
I’m pretty experienced in setting up Strats - I have 3 and used to gig them as my main guitar for years.
For physics reasons that I don’t understand, the trem setup is a key factor in perceived stiffness.
I set mine to pivot - as Leo designed - and move up and down fairly easily,
often with just two or three springs. Basically it provides more “give”. It’s also key that the nut is well cut and deeply cut. They also seem to perform better with lighter EBG strings and heavier DAE.
We will see. I will report back.
