Eric Clapton VibroChamp Control plate HOT!!!
Discussion in 'Amp Tech Center' started by Badabing, Jan 11, 2014.
  1. Badabing
    Badabing Friend of Leo's
    San Marcos, Ca
    Hey guys,
    I have a really new EC Vibrochamp and I noticed that after it is on for a while..hour or longer... the chrome control plate gets EXTREMELY Hot to the touch????
    Is this common??? Any suggestions???
    Thanks all!
  2. wtk0315
    wtk0315 Tele-Holic
    Houston area
    That doesn't sound right but I don't know for sure. A champ chassis is pretty small though so it might heat up more than say a deluxe will.
  3. Badabing
    San Marcos, Ca
    I would imagine that an amp gets hot after a while but it was pretty hot to the touch...
    I just can't imagine that it would be o.k. for it to get that hot...???
    Hopefully there will be more conversation on this...
    Not sure I can return/exchange after 30 days with Guitar Center..??
  4. fezz parka
    fezz parka ---------------------------
    Del Floria's Tailor Shop
    A tube is like 1800 degrees inside that vacuum. In a little box, that'll get hot.
  5. telex76
    telex76 Doctor of Teleocity Ad Free Member
    Fort Worth,Tx.
    Normal for it to be too hot to hold your hand on for long.
    If your worried, keep a small fan blowing towards it.
  6. Badabing
    San Marcos, Ca
    Telex
    I wasn't aware that the control plate could get that hot! your description is correct I would say it's not too hot to touch but just like you said "too hot to hold your hand on for long."
    Thanks for the info appreciate it!!
  7. Badabing
    San Marcos, Ca
    Fezz
    Never new tubes were that hot internally!! WOW!!
    Thanks for your input appreciate it!!!
  8. fezz parka
    That's why there's no air inside them. Vacuum tubes you know!
  9. simonsp
    simonsp Friend of Leo's
    England
    There's 4 valves running inside that little box, no top vent, stands to reason it's going to cook after a while.
  10. Revv23
    Revv23 Friend of Leo's
    Michigan
    Most of my amps with no control cover get like this. Like a plexi cover amp won't do this but a chrome tweed for sure will.
