Boss GE-7
LAST.
OK I lied.
ALMOST LAST.
After any sort of boost, overdrive, or compression or wah.
I've got a delay after my EQ.
the reason is, I use the EQ mostly as a clean boost, so i dont want it hitting a dirtbox first.
I was actually wondering where you put your EQ in regards to pedal order on your board?![]()
<hijack>
Are ya'll saying you like to put your clean boost pedals after the dirt? I would have thought the clean boost goes first into the dirt pedals.. Not that it really matters of course.
</hijack>
LAST.
OK I lied.
ALMOST LAST.
<hijack>
</hijack>
Cast,
You can do interesting things with 2 EQ's. Put one in front of a muff (or whatever clipping box) and one behind. Boost the highs on the upstream box... and then cut them on the downstream box. You can get the sustain on the high string without crapping up the low strings.
