Which do you favour?
FX loop makes sense to me and saves precious space on my small pedalboard. Just wondering what others do. Cheers.
It entirely depends on what you’re using it for. If you’re using it to compensate for differences in pickups, go first. If you want to shape the sound of a specific drive pedal (a highly underrated use) then go right before it. It’s it’s just overall sculpting then either first or in effects loop, but I find high gain sounds it works better in the loop. EQ is a tool more than just an effect.
+1 On top of the amp where it belongs.I know I am in the minority here on this, but I actually just place mine on top of the amp (where the input is) rather than on a pedal board. It is easier for me to adjust the controls of the EQ this way.
In that case I’d recommend early in the chain. If you run a relatively dry signal chain it might be similar if run in the loop, but I find it best to put it closest to what it’s specifically trying to shape. If you have any other filtering things like wah, or if you use an always on boost, then play around to find where it seems to work best in the first few pedals, but probably just start with first in the chain (after a tuner or any fuzz circuits that get cranky about input impedance)At the moment, I plan on using it when swapping between a CV Tele an Epi Casino.
