Epiphone SG Muse Knob Fell Off
Discussion in 'Other Guitars, other instruments' started by mrtunes, Oct 1, 2020.
  1. mrtunes
    mrtunes TDPRI Member
    I was showing this to my friend and was explaining the split coil feature and he pulled one of the volume knobs right off. I imagine he used a whole lot of force, or maybe someone had been pulling on it when it was on display in the store?
    Either way i'm wondering how to fix this because it does need to stay on properly in order to act as a split coil. Will I need a new knob and how will i find a matching one for this guitar?
  2. GeneB
    GeneB TDPRI Member Silver Supporter
    Tampa, FL
    I would trying draping a small square of tin foil over the shaft of the pot. Then carefully force the old knob down over it. Don't hammer it down, but push it in slowly and make sure it's level with the body. The foil will fill any gaps and secure it.
  3. tubegeek
    tubegeek Friend of Leo's
    Brooklyn, NY
    If the shaft is the split type, gently spread the two halves apart with a screwdriver. A little Elmer's glue might be a good fix otherwise.
    Joshiquad, teleplayr and cbh5150 like this.
  4. maggieo
    maggieo Tele-Holic Silver Supporter
    Clear nail polish works wonders, too.
    ricardo1912 likes this.
  5. mrtunes
    All good ideas here.
    how is this used?
    maggieo likes this.
  6. Whatizitman
    Whatizitman Friend of Leo's
    WV
    Take a good huff before you work on a guitar. Gets you in the right mood.
    Slip Kid, richey88, Joshiquad and 8 others like this.
  7. EsquireOK
    EsquireOK Friend of Leo's
    U.S.A.
    Hmmm...
    Have you tried putting it back on?
  8. ricardo1912
    ricardo1912 Tele-Afflicted
    Kent, UK
    Just put a drop on the post. It's sticky enough to hold bits in place but the adhesion can be broken if required later. Handy for things such as rattle Bridge screws etc. as well.
    tubegeek likes this.
  9. tubegeek
    Brooklyn, NY
    Just, do go easy on it if you use that - I'd advise a toothpick instead of the nail polish's own brush, and as mentioned, just a drop on the side of the shaft, then push the knob on. Protect the pot below the shaft and whatever the pot attaches to, the nail polish is not really great friends with plastics etc. That's why I suggested Elmer's glue - it's not aggressive in any way and you will still be able to remove the knob once it dries if you give it a good pull.
  10. maggieo
    Yep. Put the polish on the metal shaft, let it get tacky and then push the knob on. For metal parts, like a Strat trem, you can screw the arm in while the polish is still wet.
  11. DavidP
    DavidP Friend of Leo's
    Vancouver BC, Canada
    The important key word here is GENTLY!! You run the risk of snapping one of the split shafts if too much pressure is applied...
    If knobs are loose, I simply wrap the shaft a couple times (or more as required) with some plumbing tape and that works for me.
    P-Nutz, Engine Swap and maggieo like this.
  12. Engine Swap
    Engine Swap Tele-Holic
    Chicago
    +1 on GENTLY....
  13. tubegeek
    Brooklyn, NY
    I definitely should have all-capsed GENTLY, it's true. My bad.
    GENTLY. Just a skosch.
  14. P-Nutz
    P-Nutz Tele-Afflicted Silver Supporter
    Middle America
    I use a small crescent wrench on either side of the shaft to make sure that when I spread it with a small screwdriver blade, it doesn’t separate too much and break off.
  15. tubegeek
    Brooklyn, NY
    Clever!
    P-Nutz likes this.
  16. Injam
    Injam Tele-Meister
    Georgia
    Well it is made in China.
  17. DougM
    DougM Friend of Leo's
    Honolulu, HI
    I'm going to ask what no one else has. If you put the knob back on does it stay on if you pull up on it to activate the coil split without using excessive force?
    duzie and warrent like this.
  18. ZenGuitarist
    ZenGuitarist Tele-Afflicted
    Alberta, Canada
    There are 5 mentions of the word GENTLY up to now on this thread, not including quoted posts. Now there are 6.
  19. Jackroadkill
    Jackroadkill Tele-Meister
    Wales, UK
    Just smack it back on and play the guitar.
    richey88 likes this.
