EP-booster vs. MXR micro amp (allways on) into Vox style amp?
Discussion in 'The Stomp Box' started by Jussi, Apr 13, 2020.
  1. jackal
    jackal Friend of Leo's Platinum Supporter
    mojave desert
    I really like the SD Pickup Booster.
  2. codamedia
    Western Canada
    Just to be clear, a micro amp or an EP boost is just a "clean boost pedal" with a little color of their own... they are a form of pre-amp, and pre-amps have been used since the very beginning to push an amps input a little harder. They come in many forms.... from the Echoplex (tube and SS variants), clean boost pedals, treble boosters, compressors, EQ's, overdrives (eg: TS with output cranked and gain turned down), etc.... etc...
    IMO, it's more common place than it is unorthodox. The list of "who's who" that used (or still use) "always on" pre-amps to push a tube amp is really long, and goes back a long way ;)
  3. codamedia
    Western Canada
    They do sound different, if possible... get your hands on both and see which one you like more. I certainly cannot say I prefer one over the other.
    The EP has a couple dip switches internally to shape the type of boost you want, but once those are set it becomes no more flexible than the Micro Amp with a single gain knob to adjust. The Micro Amp sounds great out of the box... with a little top end boost. Out of the box the EP is darker, but can accomplish a similar tone to the MXR with the treble boost dip switch engaged.
    Just my 2 cents ;)
    Tim S likes this.
  4. Norris Vulcan
    Norris Vulcan Tele-Afflicted
    Somerset, UK
    And the list of those that don't, similarly long, tried and tested.
    The two pedals the OP mentioned - EP Boost and MXR MicroAmp - are simple circuits built around an I.C. and he is playing through an AC30 of unknown spec and vintage.
    I am just interested in why the amp isn't doing what he wants here. To have a basic SS processor as the first stage that the guitar hits, before a tube input stage, and to have this processor on all the time - it interests me as to what sound the OP is after.
    The list of devices in your post are just effects with a gain stage. "TS with output cranked and gain turned down" is using the 4558 I.C. as a SS amplifier - obviously including the tonal effects of the circuit itself - and it would be the same if you used a Compressor for 'boost', or an EQ.
    This isn't a Tube/SS comparison or anything like that, it's just "Why ?". I can appreciate that this may be how folks get "their sound" and that's fine, no quibbles.
    But a £1000 tube amp surely delivers the tone ?
    codamedia likes this.
  5. Guitarteach
    A good boost vastly adds to the versatility of any tube amp, particularly simple ones. My lovely old JMP has great bright crunch with gain at 50% and a boost makes it come alive for lead breaks. I can go from backing off the volume for clean on the guitar to a normal crunch and great singing leads with just the MXR. It makes it a three channel amp!
    I don't quite get the ‘always on’ idea though as I set the amps gain and treble higher first to get the base tone right and then tone it down with the guitar controls for super clean.
    My boost is not ‘always on’ but used to add gain and punch to an on the edge tube amp or add sparkle and cut to a single coil guitar if I swap.
    I add it in as needed.
    As well as my Microamp, i really like the independent boost on my Fulldrive 3 which has a ‘dynamics’ control.. a little germanium compressor style controls that tames the clanks a strong clean boost can add to a clean amp. That is a nice little tone conditioner. I can see the benefits of extra tone shaping options on things like an EP or TC Spark.
    Norris Vulcan likes this.
  6. Norris Vulcan
    Somerset, UK
    I totally get the "3-channel" idea using a boost, like this:
    It's the 'always on' thing I don't really get - much more versatile to turn it on and off !
  7. omahaaudio
    omahaaudio Friend of Leo's
    Omaha
    Totally unlike the EP Booster.
    :lol:
    tarheelbob likes this.
  8. Axegrinder77
    Axegrinder77 Tele-Afflicted Ad Free Member
    Springtown
    Micro amp is fantastic.
    I had an "aha!" moment with it recently. I realized why it's cream color - it adds a little cream into your tone. It doesn't change much, very very subtle, but find it adds a little clarity also. Very hard to explain. Just sounds damn good. I use it as an "usually on" set very low, unless I need boost, then I use it for that.
    Haven't played an ep, but based on what I've heard, it adds more tone or color. That might be better for you, or worse.
    You will not be disappointed with the micro amp if you're looking for a boost.
    Be aware that it's hardwire bypass. This means it can slightly suck tone when not engaged. If you have it at the end of your chain, you'll have no problem. If it's near the beginning, you might find it's better to run a buffer before it, or keep it on (then it IS the buffer). That said, its impedance is such that you might not even notice this anyways.
  9. Jussi
    Jussi Tele-Meister
    St Michel, Finland
  10. vinyldiscman
    vinyldiscman TDPRI Member
    Vineland
    Been Using the EP booster pedal for years as one of my only effects other than a Delay through a Orange Rocker 32. I only use the EP on low but leave it on all the time. Great little pedal. I believe.
    4pickupguy, tarheelbob and Jussi like this.
  11. Jussi
    Jussi Tele-Meister
    St Michel, Finland
    After all, I ended up putting a micro amp pedal on the board. Now I no longer think about the location of whether "the best" place is first or last in my chain.
    I tested micro amp before and after the my other drive pedals. Both methods works. After the drive pedals tone maybe breathe a "little" fresher... maybe.
    EP booster goes for my second board with fender silverface.
    Axegrinder77 and ravindave_3600 like this.
  12. Axegrinder77
    Springtown
    How did it work out?
    I ended up selling my micro amp, because my box of rock had a boost.. sold that too lol. So I just ordered an EP booster. I like the idea of a touch more grit and color than the mxr. It's also true bypass, which is better for my rig. (I have a tube screamer early in the chain.)
    Wish I still had the micro amp, but I can always get another one if the ep isn't my thing. I'd probably try the plus version.. true bypass and tone controls. Although, that might screw up the magic.
  13. Daytona.57
    Daytona.57 Tele-Meister
    Calabogie, On, Canada
    If you are looking at the EP Booster, you should consider the Mosky XP Booster, a clone of the EP, it is only $28.00.
    I compared the XP Booster with my Fairfield Barbershop V2, and the BSV2, was clearly superior. It was a more powerful boost and infinitely, more adjustable, with a sag, volume and gain knobs and a toggle switch for treble.
    The BSV2 was better at boosting overdrives and better for slide.
    YMMV
  14. zombiwoof
    zombiwoof Tele-Afflicted
    Tujunga California
    If you're using the Micro Amp as an "always on" boost, it doesn't matter that it isn't true bypass, because when it's on it is a buffered signal. The true bypass only comes into play when the pedal is off.
    Al
  15. twangking
    twangking Tele-Afflicted
    Out in the woods.
    I didn't care for the EP boost. Added in bass and a lot of noise with my ac30.
    MilwMark likes this.
  16. Axegrinder77
    Springtown
    i quickly sold the ep booster. Just added too much - low end and high end. was too busy for me, with not enough of what i actually wanted. Closest thing in my rig to that is my greer lightspeed - which does a way better job for me - boost with some "grit." More in the mids - where push should generally be i think. I just added a keeley compressor now as well, which can do "boost" very well it seems. Love both those pedals.
  17. 4pickupguy
    4pickupguy Doctor of Teleocity
    Fort Worth, Texas
    Allen Hinds uses quite a few SS preamps ahead of his amp. He still uses the EP-Boost even though this was ten years ago when they were ‘new’.
