Eminence Maverick
Discussion in 'Amp Central Station' started by Mark the Moose, Jan 10, 2020.
  1. Mark the Moose
    Mark the Moose Tele-Holic
    Erie, CO
    I’m hoping to get some info about the speaker itself, not just the FDM feature. I understand it gets quieter and you perceive less highs, but how would the speaker tonally compare to a 12F150 or a Red White & Blues...or something else which is fairly common? If you've owned one and can make some useful comparisons I would love to hear.
  2. jsnwhite619
    jsnwhite619 Friend of Leo's
    Georgia
    Somebody who posts regularly at Shock Brothers has one and loves it. Can't remember who though. Might try the question over there if you come up dry here.
  3. trxx
    trxx Tele-Afflicted
    Between reality and imagination
    One thing that crossed my mind about these FDM speakers is that when running a mixed pair, having control over each speaker's volume could allow for balancing one to the other, where with regular speakers you get what you get. If you have ever mixed a pair of speakers where the sound of one was overtaken by the other, you know what I mean.
    JustABluesGuy likes this.
  4. BobbyZ
    BobbyZ Doctor of Teleocity
    Snellman MN
    Can't compare the Maverick to another Eminence speaker because outside of two OEM ones in an old Sano amp I don't own any. I know they make great speakers but the sensitivity ratings are too high for me on everything but the FDM choices.
    You can get the FDM assembly on other speakers through the custom shop.
  5. JustABluesGuy
    JustABluesGuy Friend of Leo's
    Houston, TX
    I own both the Maverick and the Reignmaker, and while I can’t make any direct comparisons to other speakers they both sound great to me. IMHO Eminence did a really terrible job of marketing these amazing speakers.
    Between a few amps of varying wattage and these speakers I can cover a lot of different situations effectively.
    goldwax and BobbyZ like this.
  6. JustABluesGuy
    Houston, TX
    But only in 12” versions right?
  7. trxx
    trxx Tele-Afflicted
    Maybe they should have just advertised FDM as a custom shop option from the getgo. And they should have made it an option for 10" speakers too. It's an innovative feature, and I never heard about it until someone mentioned it recently on this forum.
  8. Mark the Moose
    Erie, CO
    I built a high-powered Princeton Reverb over the holidays with a Weber 12F150. While I don't dislike the Weber, it's crazy loud. While not many people have experience with the Maverick, I haven't found anyone who disliked it...a rarity amongst internet posters... so I'm inclined to give it a shot.
  9. aerhed
    aerhed Friend of Leo's
    Boulder, WY
    Yup i've done the HP Princeton with 12F150. Big and loud. Hard when new. The Maverick sounds similar, maybe less hard. It does sound a lot like a RWB. Pretty good, I give it an 8.5. It still sounds good attenuated to about 2/3 full then slowly becomes blah towards max attenuation. I'd call it a good work speaker.
  10. Mark the Moose
    Erie, CO
    I wonder how the magnet adjustment would combine with a output attenuator, would the negative effects compound or would it be more transparent by using each device in a more limited way?
  11. aerhed
    Boulder, WY
    My head tells me that would suck. Idk. I will say the couple good notches of attenuation from the maveriMa sounded better than any attenuator ivI' tried.
    Mark the Moose likes this.
  12. caspersvapors
    caspersvapors Tele-Meister
    CA
    wish they would put out an alnico version!
  13. BobbyZ
    Snellman MN
    As I understand it the FDM assembly only comes with 1.75 in voice coil. They make at least one 10" with a 1.75 VC maybe that would would work? An inquiry to the custom shop would be the best bet.
    I really like the Maverick and find it's range very useful. Not everyone will however because even at 91 db, the lowest setting, they put out a fair amount of volume. A gain on 10 master volume on 1 type player won't be impressed at all.
    What I've said all along is they're like an MV that only goes from 5 to 10. Very useful for gigging or warming up an amp at lower volumes but you won't get death metal distortion at bedroom volumes.
    The tone seems to change as you turn the dial but not in a bad way, to me anyway.
    Bottom line. They're speakers some will love them, some will hate them, that's just how it's is with speakers.
    Only way to find out is try one yourself. :)
  14. horseman308
    horseman308 Tele-Holic
    US
    They will put FDM on some of their 10" speakers. I'll have to dig thru my email, but somewhere I have a quote from Eminence listing the price to add it. It's not super cheap, but it might be worth it depending on your needs.
    Sent from my SM-G930P using Tapatalk
    JustABluesGuy and BobbyZ like this.
  15. BobbyZ
    Snellman MN
    I could see a 10" FDM being nice in a Princeton Reverb. You can get 10s down to about 93db which is nice for home or even some gigs but you're stuck with 93db if you need more volume. Conversely you put in something with 99 or 100 db for gigs and you're stuck with that at home. A Maverick goes from 92.5 to 99.5 db, I'm sure a 10" would be similar.
    Four of them in a Super Reverb might be ok for some guys but in amps that big I just go for the low DB stuff, one of my SRs has 93 db C10Rs. With an SR there's plenty of amp there to make all the volume I need.
    As it stands Eminece really doesn't make any speakers I'm interested in other than the FDM ones. The rest are just too darn sensitive.
  16. RoyBGood
    RoyBGood Doctor of Teleocity
    Northamptonshire, UK
    I had one a while ago. Tonally, it was ok (but nothing special) and the attenuation effect wasn't as obvious as I'd expected.
  17. W.L.Weller
    W.L.Weller Tele-Holic
    Queens
    I think I should start looking for cheap warehouse space and advertise it as an amp playground. Offer speaker break-in services, a big jam room...
    I have a RW&B and a Swamp Thang in a Fender Twin and it's a gorgeous sound in a 3000sf. warehouse. More people should have the chance to turn amps up.
  18. trxx
    trxx Tele-Afflicted
    That is interesting. I wonder why they don't mention this stuff on their site, that FDM is an option for speakers other than the Reignmaker and Maverick.
    I also wonder why Eminence offers no non-FDM speakers with lower sensitivity.
    What did you mean by "you're stuck with 93db if you need more volume"?, since it is the case that FDM adjusts from ~ 93db to 99db.
  19. trxx
    trxx Tele-Afflicted
    In general, that is what has turned me off of Emiinence to date. I tried a couple of their speakers long ago, and they were 'ok', not great. Some years later I heard a mixed pair in a 212 cab that sounded really good, and that got me curious again about Eminence. But listening to demos on their site and their youtube channel, I don't hear anything that sounds interesting or even good. They should take some input from players/customers and do some demos that really show off what their speakers can do tonally. The current demos make their speakers sound 'meh'.
  20. 8barlouie
    8barlouie Friend of Leo's Silver Supporter
    Southeast Massachusetts
    I put a Maverick in my DRRI. I think it’s a great sounding speaker with just enough attenuation to take the edge off when loudness is an issue. 8 decibels doesn’t sound like much, but it’s quite noticeable. The one thing you lose is the crystalline highs that the one C12K gives, albeit in a slightly harsh manner.
