Eminence GB128
Discussion in 'Amp Central Station' started by gibson11, Feb 25, 2018.
  1. gibson11
    gibson11 Tele-Meister
    Milwaukee, WI
    How would this sound paired with a Legend 1258 in a cab? The price is right and my Celestion Rocket is not cutting it.
  2. tarheelbob
    tarheelbob Tele-Holic Silver Supporter
    Asheville
    um, how would what sound...?
  3. gibson11
    Milwaukee, WI
    Stratocaster w/Egnator Tweaker into a carvin cab for Rock, blues, and jazz
  4. igor5
    igor5 Tele-Meister
    Chicago
    I own one that. And I really like it. I guess "GB" means "greenback"... It's pretty loud.
  5. homesick345
    Beirut, Lebanon
    it will sound awesome
    I don't see how this could suck
    emisilly likes this.
  6. noname_dragon
    noname_dragon Tele-Holic
    North east coast
    That's an excellent pair of speakers. In fact it's marketed as the "crankin' country'" set. I put the pair in a '66 Band Master that I customized with a partial open back. It's Fender with some added midrange thickness from the GB. The 1258 is what you would expect from a good original C12N.
    tho618 likes this.
  7. tho618
    tho618 TDPRI Member
    Swampscott, MA
    I would think awesome. I own both. 1258 has tight lows and great sparkle. GB has rounder, looser lows, fantastic grit bit with a chimey clarity. To me they will compliment each other very well.
  8. gibson11
    Milwaukee, WI
    Thanks for the input, just bid on a GB128, it will be awesome
  9. Axis29
    Axis29 Poster Extraordinaire Silver Supporter
    Beaumont, CA
    I don't have any direct experience with a GB128. But, I have a Celestion Creamback 65 (that people kinda equate/compare with Greannbacks) paired with a 1258 in my old '58 Twin. It sounds quite good. It was a much better pair than I anticipated! I was most worried about the disparity in efficiency, but it seems to have worked out fine.
    I love pairing different speakers - magnets, tonal range, etc. As long as both speakers are good at something, I think you end up with the best of both speakers a lot of the time. I haven't put two weird things together yet and not been happy with the end result.
  10. gibson11
    Milwaukee, WI
    The band master was my first amp, sold it off years ago, loved the smell as it warmed up.
  11. barfoden
    barfoden Tele-Meister
    Sweden
    The GB128 has a high efficiency but to my ears (1x12 open back cab), it has a wide midrange band (300Hz to 800Hz), big boomy low and less cutting high mids (1kHz to 2Khz) which requires a healthy dose of EQ to make it cut in a band situation.
    with my particular bass heavy amp I need to lower the bass pot to 9 oclock, mids 10 o'clock (low center frequency on the midrange control) and increase the treble to at least 2 o'clock.
    When doing this you loose a bit of sensitivity because i need to lower the mids and bass and increase the treble to cut through.. It might be slightly an effect of the undoped nature of the speaker.
    northernguitar likes this.
  12. TequilaCaster
    TequilaCaster Tele-Holic
    Between Time and Space
    My experience with the GB128 was the same. It sounds great when playing by yourself or recording, but it disappears in a live band mix. I never could EQ my amp to make it work on a gig. A V30 replaced it for performances.
    northernguitar, D_Malone and barfoden like this.
  13. schenkadere
    schenkadere Friend of Leo's
    NY
    The GB128 is a great speaker and doesn't break the bank. I one in a Randall 12" combo and it makes the amp.
  14. barfoden
    Sweden
    I think it fairs better in a small closed back cab where the trapped air can act as a spring on cone movement raising the speakers Rf and giving it a tighter bass response and a sligtly different mid response
  15. D_Malone
    D_Malone Tele-Holic
    Ferndale, MI
    This has been my experience as well. I was surprised by how dark it is. I much prefer the Celestion G12M Greenback, G12M-65 and G12H-75 Creambacks. But, with a bright amp the Eminence could work well. I’ve had many Eminence speakers and they’re all great.
    northernguitar and uriah1 like this.
  16. zook
    zook Friend of Leo's
    Cochise, AZ
    I think it's more likely that GB stands for "Great Britain"
  17. D_Malone
    D_Malone Tele-Holic
    Ferndale, MI
    Maybe. I can’t say for sure if that’s true, but this speaker definitely lacks the upper mid/high end sizzle and bark one would expect from a British-voiced speaker.
    I’m not knocking Eminence. They make great speakers, but this one is not an alternative to a Celestion in my opinion.
  18. vanr
    vanr Tele-Afflicted
    AZ
    After being a Celestion guy all my life, I've found that the GB128 or V12 is all I need. Either one is fine. Changing to Eminence took the fizz out of my tone. And that's good.
    Wally likes this.
  19. Bartholomew3
    Bartholomew3 Friend of Leo's
    Montreal
    I have a 68 silverface drip-edge twin that I bought new that year. Recently replaced original blown speakers with GB128 plus a 1258 Legend.
    Works really well but due to weight it's my living-room amp now so still haven't used it at gig volume levels in a club and probably never will again.
    Downsized... Am a tube nut but have to say the new Champion 40 I just bought sounds just like that old twin and weighs nothing.
    Wally likes this.
