email exchange with warmoth
Discussion in 'Other T-Types and Partscasters' started by chucker, Mar 4, 2021.
  1. chucker
    chucker TDPRI Member
    New York
    my issue was keeping neck weight down. spike at warmoth advised using light weight tuners, and not opting for the modern truss rod which adds 4 oz. to a neck. he recommended the vintage/modern. i really like the modern truss rod engineering but there are situations where the weight is an issue.
    glad i asked as i had no idea.
    El Tele Lobo likes this.
  2. schmee
    schmee Doctor of Teleocity
    I had a few Warmoth necks a couple years ago. I bought some with the side adjust truss rod because they were in their "ready to buy" shop. I didn't like that truss rod because it seemed to need adjusting more often and you have to be careful how you do it. And one thing I noticed while handling the necks is yes that side adjust dual rod is noticeably heavier! At first I thought it was my imagination but then I put one neck in one hand and the other in the other hand and did some guessing. Definitely heavy!
    pdmartin likes this.
  3. ucnick
    ucnick Tele-Meister Gold Supporter
    Union City CA
    Hipshot locking open tuners are pretty light, they helped me with reducing neck dive...
  4. El Tele Lobo
    El Tele Lobo Poster Extraordinaire
    Yeah. I like the convenience of a headstock adjust modern double-acting rod, but I like the weight and weight distribution of a vintage heel-adjust neck. My necks tend toward the thicker side and I don't have to adjust them much, so it's not a big deal.
  5. tfarny
    tfarny Friend of Leo's
    Hudson Valley, NY
    I've bought a lot of Warmoth necks, and I always find that the "pro" construction necks don't tend to stick around. It's a solution in search of a problem and you end up with too much metal inside the neck. And the side adjust is clever and convenient - but kinda ugly and out of place imhop.
    Nightclub Dwight likes this.
  6. Peegoo
    Peegoo Poster Extraordinaire
    Between the Raindrops
    Hardware matters.
    The hardware you choose is a lot like everything you carry with you when hiking: ounces matter because a few extra ones here and there add up to pounds. Do you really need a 1.5-lb Bowie knife and a hatchet? You have to carefully choose what you'll take with you to make things as easy as possible on a long trip.
    I know I'm a nut, but I like the Gotoh side-adjust rod. I set and forget; they work great for me.
    FenderLover and Ron C like this.
  7. Ron C
    Ron C Tele-Holic
    Long Island, New York
    Yep, hardware definitely matters if you’re working with a light body. Vintage tuners, single action truss rod, skip the dense exotic neck woods. Roasted maple shaves some weight too. Next put on a heavy bridge and heavy knobs, and then maybe the super light body that was so exciting to buy won’t do the neck dive dance.
  8. Drak
    Drak Tele-Holic
    DC 'Burbs
    I discovered they (Warmoth) made a great YT on explaining and showing that damn double-rod.
    I have multiple Warmoths of both kinds.
    It really does add some appreciable weight, there really is a difference.
    So I generally don't use them on any 'super-light' builds.
    Beyond that, I don't really care one way or the other.
    But when you SEE what's inside...it explains a lot.
  9. Loudog99
    Loudog99 Tele-Holic
    Howell, NJ
    I just got a vintage modern with the single action truss rod and neck adjustment. Feels much lighter in hand than a modern neck I recently worked on. Great workmanship too, which will require very little fretwork.
  10. pinchegil
    pinchegil Tele-Meister Platinum Supporter
    Roxborough Park, CO
    Bigsby = no neck dive :)
    gerhard_k likes this.
  11. takauya
    takauya Tele-Meister
    Forest
