Elevate center tap or send to ground?
Blueslover88
In the RR2104 it shows the artificial center tap bring elevated. Do I need to do this if I have an actual center tap or just solder to ground lug?
SerpentRuss
North Carolina
Any amp build with a long tail pair phase inverter and/or a cathode follower will benefit from an elevated heater ground. The voltage divider used to get the reference voltage will also act as a bleed for the power supply capacitors.
Blueslover88
So I can just land the center tap at the top of the 180k voltage divedr/bleeder right?
cottontails1959
Pittsburgh, PA
Per Blencowe ... "The DC voltage is applied to ... whatever reference connection the heater supply would normally have. The elevation voltage can be taken from a potential divider across the HT (it doesn't matter where you position the divider), and an elevation voltage around 30 to 60V is typical." and "The elevation voltage should be decoupled/smoothed with an arbitrarily large capacitor (C1), say 10uF or more." IIRC, if your transformer has a heater center tap, use that - no need for an artificial center tap. You land the CT in the "center" of the voltage divider ... the junction of R1:R2 ... for example, if the divider is 180K:39K with 340V, the heater elevation is 340*(39/(39+180)) = 60.5V. However, as @dan40 asks, a schematic or layout drawing will help.
SerpentRuss
North Carolina
Here is an example. You want the total resistance to be fairly large, but not too large. Just pick your resistors based on your B+ voltage and mind the wattages so they can handle the power.
Blueslover88
Is this an actual divider that is set up to give the correct voltage or is it simply a bleeder resistor? Do you have a schematic or layout drawing of this?
  • RR2104_Master_Volume_Micro_EF80_Layout (1).pdf
Blueslover88
I posted below it's Rob's jcm 800 ef80 build
Blueslover88
Yep...just attach your CT to the same turret that the green/yellow wire is attached to in the layout.
Here is the finished product. Not as clean as I'd like but it leaves something to do when I get bored. I may run the leads under the board at some point but SUPER happy with the sound
dan40
Richmond Va
Congratulations on a successful build! I have a stash of old EF80's and I have been contemplating building this circuit myself. It's down to either this one or the micro Bassman.
Blueslover88
Thanks Dan. I built a KLD 5e3 kit first. Then I built a micro 5e3 with 12au7 power tube. I had leftover parts so I built the 5e3 with ef80. I didn't care much for the ef80 5e3 so I stole some of it's components to make this jcm800 and boy am I glad I did!
