Electrolytic values?
Discussion in 'Burnt Fingers DIY Effects' started by Mark the Moose, Apr 17, 2020.
  1. Mark the Moose
    Mark the Moose Tele-Holic
    Erie, CO
    I’m working on a strip board build and I’ve run out of 22uf electrolytic caps. Think it will affect the sound if I sub out for 33uf?
  2. Engine Swap
    Engine Swap Tele-Holic
    Chicago
    Schematic? Most electrolyics are +/- 20% tolerence.
  3. Mark the Moose
    Erie, CO
    No schematic. But I was fairly certain that the electrolytics are mostly related to power and not part of the signal.
  4. JunkMcNuggets
    JunkMcNuggets NEW MEMBER!
    Ohio
    Looks like all source bypass caps but I'd get a second opinion. If anything there might be a touch more gain through those 33u caps and the frequency at which the gain or whatever rolls off, will shift slightly , and bigger caps would shift it a bit lower. in my limited and general experience and experimentation, at that size the gain doesn't always have a noticable different when the Caps are that large to begin with. You might be able to hear a.change though.
  5. JunkMcNuggets
    Ohio
    In shortyoure good to sub em
    Id bet and it shouldnt Make a huge difference between the two values In thosre positions especially otherwise.
  6. LightningPhil
    LightningPhil Tele-Meister
    Nottingham, UK
    Bung them in and see what happens. Perhaps slightly lower noise?
